World File Rasters?
Hello guys and gals!
We've recently received Civil 3D 2008 to process our survey data. One of the biggest questions is this. How do we import our Mr. SID files to georeference to our RTK surveys? We currently don't have the full package of Raster Design. And I've heard that AutoCAD doesn't use the reference file associated with the Mr. SID is this true? Thanks for your help!
Use Map > Image > Insert, this will read .tfw (world) files. Not sure about MrSid though.
I tried but couldn't get mapiinsert to work with MrSID files, but you can use Map to connect to the .sid files. Look under Help for MrSID, they explain how to. If you're unfamiliar with Map, to bring up the Display Manager, type in MAPWSPACE.
I believe you also have to have the Raster Design object enablers in order to do MrSID or Jpeg2000 formats.
I'm pretty sure that is right. I had forgotten about that.
Download "infranview" and save your mrSID's to something that is supported by C3D eg. tif, jpg. World files are just txt files so depending on what your image is rename the ext of the world file.
eg: tif = tfw
jpg = jpw
sid = sdw
