Reaper_of_Lykos Posted May 3, 2023 Posted May 3, 2023 I have a block that represents a section of a duct. It has custom properties of "Duct_Width". I am trying to gte the property through lisp using: (vlax-get-property (vlax-ename->vla-object (car (entsel))) "Duct_Width") but I get an error saying "unknown name: Duct_Width". Is it that vlax-get-property does not work on customized parameters? Is there a way I can retrieve "Duct_Width"? And if possible, how to set it? Thank you very much. Quote
ronjonp Posted May 3, 2023 Posted May 3, 2023 Sounds like a dynamic block. Post a sample drawing. Quote
Lee Mac Posted May 3, 2023 Posted May 3, 2023 Try using my Get Dynamic Block Property Value function, e.g.: (LM:getdynpropvalue (vlax-ename->vla-object (car (entsel))) "Duct_Width") Quote
Reaper_of_Lykos Posted May 4, 2023 Author Posted May 4, 2023 20 hours ago, ronjonp said: Sounds like a dynamic block. Post a sample drawing. It is a dynamic block indeed. Please see attached sample duct. Duct Sample.dwg Quote
ronjonp Posted May 4, 2023 Posted May 4, 2023 8 minutes ago, Reaper_of_Lykos said: It is a dynamic block indeed. Please see attached sample duct. Duct Sample.dwg 149.41 kB · 0 downloads Lee's got you covered in the post above. Quote
Reaper_of_Lykos Posted May 4, 2023 Author Posted May 4, 2023 20 hours ago, Lee Mac said: Try using my Get Dynamic Block Property Value function, e.g.: (LM:getdynpropvalue (vlax-ename->vla-object (car (entsel))) "Duct_Width") Hi Lee Mac, your function works great, as well as the set property one, thanks a lot! Quote
Lee Mac Posted May 4, 2023 Posted May 4, 2023 1 hour ago, Reaper_of_Lykos said: Hi Lee Mac, your function works great, as well as the set property one, thanks a lot! Great stuff - you're welcome! Quote
BIGAL Posted May 5, 2023 Posted May 5, 2023 Thanks to you Lee this is insert a block and pop the visibility states in a dcl so can choose rather than go to properties to set. ; Change dynamic block properties when inserting look at properties available. ; By Alan H June 2022 ;; Get Dynamic Block Property Allowed Values - Lee Mac ;; Returns the allowed values for a specific Dynamic Block property. ;; Set Dynamic Block Visibility State - Lee Mac ;; Sets the Visibility Parameter of a Dynamic Block (if present) to a specific value (if allowed) ;; Get Visibility Parameter Name - Lee Mac ;; Returns the name of the Visibility Parameter of a Dynamic Block (if present) (defun insdynv (blkname / pt obj lst ans) (if (not LM:setdynpropvalue )(load "Lee-mac Dynamic block get-put")) (setq pt (getpoint "\nPick a pt for block ")) (command "-insert" blkname "s" 1.0 pt 0) (setq obj (vlax-ename->vla-object (entlast))) (setq visval (LM:getvisibilityparametername obj)) (setq lst (LM:getdynpropallowedvalues obj visval)) (setq lst (cons "Please choose" lst)) (if (not AH:Butts)(load "Multi Radio buttons.lsp")) (if (not AHbut)(setq AHbut 1)) (setq ans (ah:butts 1 "v" lst)) (LM:SetVisibilityState obj ans) (princ) ) ; set existing block visibilty (defun insdyne (blkname / pt obj lst ans) (if (not LM:setdynpropvalue )(load "Lee-mac Dynamic block get-put")) (if (not AH:Butts)(load "Multi Radio buttons.lsp")) (setq obj (vlax-ename->vla-object (car (entsel "\nPick a dynamic block ")))) (setq visval (LM:getvisibilityparametername obj)) (setq lst (LM:getdynpropallowedvalues obj visval)) (setq lst (cons "Please choose" lst)) (if (not AH:Butts)(load "Multi Radio buttons.lsp")) (if (not AHbut)(setq AHbut 1)) (setq ans (ah:butts 1 "v" lst)) (LM:SetVisibilityState obj ans) (princ) ) Need multi radio buttons save in a support path location or edit the (load "Multi radio buttons") with correct path. Same with input values would use Multi getvals.lsp with LM:getdynprops Multi radio buttons.lsp Quote
