how to make text break a line?
ive seen drawings where if write text over a line, it will blank out the line, while the line remains one(just not visibly).
how do i do this? ive tried a search. but as u can see by my lame explanation
i have no clue how to word this correctly
Use MText and turn on TEXT MASK from the text's properties. This can also be applied through MATCHPROP (Match Properties).
thanx.
is there anyway i can do this by default
thanx.
anybody? ?
I am not sure if this can be done by default, I am sure ReMark will know, guy knows everything.
What I ususally do is with MText, click on the little options arrow and then use background mask, which you can then set to be any color you like, or the same as your drawing background. And, like previously stated, MATCHPROP (or just MA on the command line) will allow you to do it once and then apply it to any other pieces of text you select. Hope this helps
