Ish Posted May 11 Share Posted May 11 Dear team , I used etransmit command >add file than bind xref option, but not bind in current drawing. Is any tools or lisp, VBA macro for add multiple xref and bind together in current file and save as a zip file.? Note :, Xref not attached in current drawing. I need to attach multiple and bind together in current drawing. Thanks Quote Link to comment Share on other sites More sharing options...
Steven P Posted May 11 Share Posted May 11 I don't have anything but the command "XA" - Xref Attach runs through the command line and can be used such as: (command "XA" -FilePath- ......) If you know the files to attach, create a list with the LISP and loop through that to XA them all Next step, binding, -xref runs with the command line, and so with LISP (command "-xref" "Bind" .....) And you could probably combine these 2 lines together with the -xref command that should attach many xrefs and bind them to the current drawing - needs you to produce a list of drawings to use and the insertion points as a start Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 12 Share Posted May 12 (edited) I can unzip from CAD uses Powershell a inbuilt command in windows, ok so could do a zip problem I see is if have dwg open the zip may work or worse zip up a not saved version. So you would need to save the dwg then zip it. Using a script it could be possible. Google powershell zip file. This is unzip, filename is passed from lisp. (startapp (strcat "powershell -command Expand-Archive -Path '" filename "' -DestinationPath 'C:/CAD-TOOLS' -FORCE")) ok feel generous (setq filename "d:\\acadtemp\\testbrics.bmp") (startapp (strcat "powershell -command Compress-Archive -path '" filename "' -DestinationPath 'D:/Acadtemp/testvrics.zip'")) Edited May 12 by BIGAL Quote Link to comment Share on other sites More sharing options...
Ish Posted May 12 Author Share Posted May 12 Sir, actually I need to attach xref from the directory by selecting, example I have 15 xref but required only 7. -------- Attached multiple xref Bind Purge Zip file 4 in 1 process Quote Link to comment Share on other sites More sharing options...
Steven P Posted May 12 Share Posted May 12 have you tried making up some LISP code for this by the way? and how far have you got? Try making up a simple LISP to attach and bind a single xref, you can just write in the filepath of the file for now and get that working using the hints above Purge is easy (command "PURGE" "A" "*" "N") and repeat that line 2 or 3 times just in case BIgAl has given how to ZIP a file above, it should be al here for you to put together Post that and ask how to select multiple files though this (http://www.lee-mac.com/getfilesdialog.html) will let you select multiple files Make it work for 1 file, post your code, and then we can work on making it work for many files - a great way to learn trying it yourself Quote Link to comment Share on other sites More sharing options...
