Bob658 Posted May 18, 2023 Posted May 18, 2023 I use Datalink to import schedules from Excel. Which I then insert as a table. Up until recently everything was fine and height of the text in AutoCAD was roughly in line with the point size in Excel e.g. text height in AutoCAD 3.528 units and Excel point size 14. However I have just bought a new PC and installed the same AutoCAD software but when I insert a table the text height has changed to 2.469 units. What makes this particularly weird is that if I go back to my old PC and re-insert the schedule it's OK. Could this be caused by a system variable that I may have inadvertently changed? test.dwg Test excel.xlsx Quote
