Hi, can some please help with adding a function to exclude a range of layout tabs.
I want the Lisp routine to start calculating the page no from tab 01, refer to image.
The LISP for adding the total number of pages is as follow,
;Sets totalLayouts automatically - then use Field: %<\AcVar.17.0 Lisp.totallayouts>%
(defun _totalLayoutsReactor (a r)
 (setq totalLayouts (length (layoutlist)))
(vlr-command-reactor nil '((:vlr-commandWillStart . _totalLayoutsReactor)))
Thank you in advance......
If this is for something in the title block? I would use text fields.
%<\AcVar CTAB \f "%tc1">%
this would equal "01" on tab 01
Else this will create a list.
(setq Layerlst (layoutlist))
("Model" "Cover" "Rev LOG" .... "09")
Use vl-position to find where "01" is in the list.
(setq pos (vl-position "01" Layerlst)) = 8
This is because the first position is always 0
now all you need to do is subtract the remaining strings from the position of "01"
(setq total (-  (length Layerlst) pos))
      total = (- (17) 8))
      total = (- 17 8))
      total = 9
Thank you for your response.
I am using this, "%<\AcVar CTAB \f "%tc1">% this would equal "01" on tab 01" for the page number yes.
But iI'm looking for a solution will keep the total page number at the end the same.
I would look at a slightly different approach, and that is rather than trying to do auto updates just run a lisp and update the two attributes, the total would be a case of whether a layout name is a number only, and then just count those up for the total. So A01 would be accepted or not is up to you. Mhupp has provided a look for "01" code and work out total.
With your example:
(length (member "01" (layoutlist)))
Will return the total.
