quyenpv Posted May 20, 2023 Posted May 20, 2023 I found a Lisp that records the length at the midpoint written by Lee Mac (Length at Midpoint). I want to help write an additional function that outputs Excel the length of the selected object to a Sheet of information including order, object, length. After the statement ends, if the user continues to execute, write the next result from the last line of Sheet I also found the list to export to Excel but I don't know how to edit it to make the lisp as complete as I want it to be ; by patrick_35 ; mods by beekeecz (vl-load-com) (defun c:test(/ doc ent lin xls wks) (setq doc (vla-get-activedocument (vlax-get-acad-object))) (vla-startundomark doc) (and (ssget '((0 . "LINE,ARC"))) (progn (setq xls (vlax-get-or-create-object "Excel.Application")) (or (setq wks (vlax-get xls 'ActiveSheet)) (vlax-invoke (vlax-get xls 'workbooks) 'Add) ) (setq wks (vlax-get xls 'ActiveSheet) lin 2 ) (vlax-put xls 'Visible :vlax-true) (vlax-put (vlax-get-property wks 'range "A1") 'value "StartPoint-X") (vlax-put (vlax-get-property wks 'range "B1") 'value "StartPoint-Y") (vlax-put (vlax-get-property wks 'range "C1") 'value "EndPoint-X") (vlax-put (vlax-get-property wks 'range "D1") 'value "EndPoint-Y") (vlax-put (vlax-get-property wks 'range "E1") 'value "Center-X") (vlax-put (vlax-get-property wks 'range "F1") 'value "Center-Y") (vlax-for ent (setq sel (vla-get-activeselectionset doc)) (vlax-put (vlax-get-property wks 'range (strcat "A" (itoa lin))) 'value (car (trans (vlax-get ent 'startpoint) 1 0))) (vlax-put (vlax-get-property wks 'range (strcat "B" (itoa lin))) 'value (cadr (trans (vlax-get ent 'startpoint) 1 0))) (vlax-put (vlax-get-property wks 'range (strcat "C" (itoa lin))) 'value (car (trans (vlax-get ent 'endpoint) 1 0))) (vlax-put (vlax-get-property wks 'range (strcat "D" (itoa lin))) 'value (cadr (trans (vlax-get ent 'endpoint) 1 0))) (vlax-put (vlax-get-property wks 'range (strcat "E" (itoa lin))) 'value (car (if (= "AcDbArc" (vlax-get ent 'objectname)) (trans (vlax-get ent 'center) 1 0) '(0 0 0)))) (vlax-put (vlax-get-property wks 'range (strcat "F" (itoa lin))) 'value (cadr (if (= "AcDbArc" (vlax-get ent 'objectname)) (trans (vlax-get ent 'center) 1 0) '(0 0 0)))) (setq lin (1+ lin)) ) (vla-delete sel) (mapcar 'vlax-release-object (list wks xls)) (gc)(gc) ) ) (vla-endundomark doc) (princ) ) MidLenV1-1 (1).lsp Test.lsp Quote
devitg Posted May 20, 2023 Posted May 20, 2023 7 hours ago, quyenpv said: I found a Lisp that records the length at the midpoint written by Lee Mac (Length at Midpoint). I want to help write an additional function that outputs Excel the length of the selected object to a Sheet of information including order, object, length. After the statement ends, if the user continues to execute, write the next result from the last line of Sheet I also found the list to export to Excel but I don't know how to edit it to make the lisp as complete as I want it to be ; by patrick_35 ; mods by beekeecz (vl-load-com) (defun c:test(/ doc ent lin xls wks) (setq doc (vla-get-activedocument (vlax-get-acad-object))) (vla-startundomark doc) (and (ssget '((0 . "LINE,ARC"))) (progn (setq xls (vlax-get-or-create-object "Excel.Application")) (or (setq wks (vlax-get xls 'ActiveSheet)) (vlax-invoke (vlax-get xls 'workbooks) 'Add) ) (setq wks (vlax-get xls 'ActiveSheet) lin 2 ) (vlax-put xls 'Visible :vlax-true) (vlax-put (vlax-get-property wks 'range "A1") 'value "StartPoint-X") (vlax-put (vlax-get-property wks 'range "B1") 'value "StartPoint-Y") (vlax-put (vlax-get-property wks 'range "C1") 'value "EndPoint-X") (vlax-put (vlax-get-property wks 'range "D1") 'value "EndPoint-Y") (vlax-put (vlax-get-property wks 'range "E1") 'value "Center-X") (vlax-put (vlax-get-property wks 'range "F1") 'value "Center-Y") (vlax-for ent (setq sel (vla-get-activeselectionset doc)) (vlax-put (vlax-get-property wks 'range (strcat "A" (itoa lin))) 'value (car (trans (vlax-get ent 'startpoint) 1 0))) (vlax-put (vlax-get-property wks 'range (strcat "B" (itoa lin))) 'value (cadr (trans (vlax-get ent 'startpoint) 1 0))) (vlax-put (vlax-get-property wks 'range (strcat "C" (itoa lin))) 'value (car (trans (vlax-get ent 'endpoint) 1 0))) (vlax-put (vlax-get-property wks 'range (strcat "D" (itoa lin))) 'value (cadr (trans (vlax-get ent 'endpoint) 1 0))) (vlax-put (vlax-get-property wks 'range (strcat "E" (itoa lin))) 'value (car (if (= "AcDbArc" (vlax-get ent 'objectname)) (trans (vlax-get ent 'center) 1 0) '(0 0 0)))) (vlax-put (vlax-get-property wks 'range (strcat "F" (itoa lin))) 'value (cadr (if (= "AcDbArc" (vlax-get ent 'objectname)) (trans (vlax-get ent 'center) 1 0) '(0 0 0)))) (setq lin (1+ lin)) ) (vla-delete sel) (mapcar 'vlax-release-object (list wks xls)) (gc)(gc) ) ) (vla-endundomark doc) (princ) ) MidLenV1-1 (1).lsp 7.55 kB · 1 download Test.lsp 2.37 kB · 2 downloads @quyenpv please upload sample.dwg Quote
BIGAL Posted May 21, 2023 Posted May 21, 2023 Excel has a few combos to do with is already open or not so can check this. Easiest is to not have excel open and let your code open it. Or have a blank excel open. (or (setq myxl (vlax-get-object "Excel.Application")) (setq myxl (vlax-get-or-create-object "excel.Application")) ) (vla-put-visible myXL :vlax-true) (vlax-put-property myxl 'ScreenUpdating :vlax-true) (vlax-put-property myXL 'DisplayAlerts :vlax-true) The reason I mention this is your using the ADD function and it may not be necessary. Its possibly better to open or check what file is open if you want to add a new worksheet. You can use (alert "make sure Excel is closed") this will stop Acad while you check. (setq myxl (vlax-get-object "Excel.Application")) nil No Excel is open so can use this as a check (setq myxl (vlax-get-object "Excel.Application")) #<VLA-OBJECT _Application 000000006C4CC198> Excel is open so can get say file name and check and use or make a new one. Quote
quyenpv Posted May 21, 2023 Author Posted May 21, 2023 Because this statistics is not necessary to store, if the first time excel does not have the program, it will start and create a Workbook and add a new Sheet. If yes, then add information to Sheet There is a need to fix more here 1. Check the box to insert data, if there is old data, ask the user if he wants to overwrite it 2. If in Autocad run the command n times after the first time, the results will continue to be recorded in the last line of Sheet Quote
quyenpv Posted May 21, 2023 Author Posted May 21, 2023 (vl-load-com) (defun c:test(/ doc ent lin xls wks rng) (setq doc (vla-get-activedocument (vlax-get-acad-object))) (vla-startundomark doc) (and (ssget '((0 . "LINE,ARC"))) (progn (setq xls (vlax-get-or-create-object "Excel.Application")) (or (setq wks (vlax-get xls 'ActiveSheet)) (vlax-invoke (vlax-get xls 'workbooks) 'Add) ) (setq wks (vlax-get xls 'ActiveSheet)) (vlax-put xls 'Visible :vlax-true) (setq rng (vlax-get (vlax-get wks 'UsedRange) 'Rows)) (setq lin (1+ (vla-get-count rng))) ; Add 1 to the count to get the next empty row (if (= lin 2) ; If the Excel file is empty, we create headers (progn (vlax-put (vlax-get-property wks 'range "A1") 'value "Object Order") (vlax-put (vlax-get-property wks 'range "B1") 'value "Object Length") (setq lin 2) ) ) (vlax-for ent (setq sel (vla-get-activeselectionset doc)) (vlax-put (vlax-get-property wks 'range (strcat "A" (itoa lin))) 'value (- lin 1)) ; We start from 1 (vlax-put (vlax-get-property wks 'range (strcat "B" (itoa lin))) 'value (rtos (vla-get-length ent) 2 2)) ; Round the length to 2 decimal places (setq lin (1+ lin)) ) (vla-delete sel) (mapcar 'vlax-release-object (list wks xls)) (gc)(gc) ) ) (vla-endundomark doc) (princ) ) Quote
Tsuky Posted May 21, 2023 Posted May 21, 2023 For Arc is not Length but ArcLength, you must change (vlax-put (vlax-get-property wks 'range (strcat "B" (itoa lin))) 'value (rtos (vla-get-length ent) 2 2)) ; Round the length to 2 decimal places to (vlax-put (vlax-get-property wks 'range (strcat "B" (itoa lin))) 'value (rtos (if (eq (vla-get-objectname ent) "AcDbLine") (vla-get-length ent) (vla-get-arclength ent)) 2 2)) ; Round the length to 2 decimal places Quote
quyenpv Posted May 22, 2023 Author Posted May 22, 2023 I want to combine the lisp written by Lee Mac with exporting to Excel so that when selecting an object, I simultaneously record the length of the object into Autocad and output it to Excel at the same time. Quote
devitg Posted May 22, 2023 Posted May 22, 2023 9 hours ago, quyenpv said: I want to combine the lisp written by Lee Mac with exporting to Excel so that when selecting an object, I simultaneously record the length of the object into Autocad and output it to Excel at the same time. @quyenpv Would you accept a CSV file , it can be open by XLS , and it will be easy to implement , it will add new line each time you use. Please upload a xls sample as you need the columns to be. Quote
BIGAL Posted May 23, 2023 Posted May 23, 2023 "I simultaneously record the length into Autocad and output it to Excel at the same time." Yes "putcell" function. (vlax-put (vlax-get-property wks 'range "D21" 'value length)) Ok now for the part you need when working in Autocad think rows and columns, ie 20,5 would be row 20 column 5, but in excel its "E20". So the solution is convert x,y to alphanumber. I would look at Getexcel.lsp for the answer it is in there, and use it with your existing code. I use a home grown version which started with getexcel.lsp. This is my put cell function. (defun putcell (cellname val1 / ) (setq myRange (vlax-get-property (vlax-get-property myxl "ActiveSheet") "Range" cellname)) (vlax-put-property myRange 'Value2 val1) ) So here is a hint, its in Getexcel.lsp needed for cellname. ; Number2Alpha - Converts Number into Alpha string ; Function By: Gilles Chanteau from Marseille, France ; Arguments: 1 ; Num# = Number to convert ; Syntax example: (Number2Alpha 731) = "ABC" getexecel.lsp Quote
