I am trying to change the lineweight and make some dashed lines.
I know that you can select lines, right click, to get to the properties bar and do this. That is fine, i have done that before
The properties bar
like shown below i where I am trying to get to.
Now the problem is that I can not get to this properties bar.
When i select and rightclick on a line and select Properties on the menu- Nothing happens.
Why wont the task bar come up and how do i get it back?
screen.pdf
I'm not sure I understand your problem but heres my try:
1. Format > Linetype... > Load...
or
2. LT > Alt + L.
After loading your dashed lines you can get back to the properties dialogue box and you can see whatever linetype you have loaded.
Thanks,
I know that the problem is deeming to be a little hard to explain.
Basically I cant get a Properties bar to show up.
Pickfirst is at 1.
I added a screen shot if that helps?
Another long shot, but does typing CH on the command line do anything :?
Pickfirst is at 1.
it looks broken :cry:
that often happens if PICKFIRST is set to 0 - its the "No Selection" that is the problem. Can you select anything using the buttons on the top right of the Properties palette?
Try to turn on autohide in your taskbar. See if you can see portion of your properties dialogue.
I recently changed anti-virus software to *v*st, and I kept on losing my menu, which would not reload. I solved it by rebooting, and all was fine until the next time. I have now uninstalled *v*st and re-installed AVG, and everything seems to be fine again.
I knew I'd seen this problem before but totally forgot the answer. Even more embarrassing - I'm sure I commented on the last case with something along the lines "I'll try to remember that for next time".
Well, you know what they say? The mind is the first thing to go. :lol: :whistle: o:)
Although, I didn't think of it either, when I saw this question yesterday. It wasn't until I re-read it this morning that the light clicked on. :idea:
Yes this is occurring in every file that I open. I tried to open some old files that I was using last year and it wasn’t working for those wither.
Haven’t used any registry cleaners lately or that I know of, ill have to check my anti virus software.
Hey, Thanks guys for the help.
Problem now solved. I did the repair install option and it is fixed. I have my properties bar back. Am real greatfull for your help.
