Hello,
i'm trying to hatch a dynamic block reference through VBA and i cant get it to work.
A summary of the routine is as follows:
Dim BIMOBJ As AcadBlockReference
Set BIMOBJ = ThisDrawing.ModelSpace.InsertBlock(center, BN, 1, 1, 1, Ang)         --> (Dont mind those parameters, they work correctly, the block reference is inserted correctly)
Dim objhatch As AcadHatch
Set objhatch = ThisDrawing.ModelSpace.AddHatch(acHatchPatternTypePreDefined, "ANSI31", True, acHatchObject)
Dim OuterLim() As AcadEntity
ReDim OuterLim(0)
--- FROM HERE ON I DONT KNOW WHAT TO DO------
Set OuterLim(0) =BIMOBJ   -->>???
Dim blockent As AcadEntity: Set blockent = BIMOBJ
Set OuterLim(0) =blockent   -->>???
objhatch.AppendOuterLoop (OuterLim)     -->This is the part that is now working. I don tknow how to define a blockreference as OuterLoop
By the way, if I command-hatch manualy via autocad modelspace interface, selecting the blockreference, the hatch is done correctly and works great.
Any Ideas?
Thanks!
On 6/18/2023 at 7:04 AM, German said:
Hello,
ReDim OuterLim(0)
Any Ideas?
Thanks!
@German  better if you post at vba forum
vba
