leonucadomi Posted June 22, 2023 Share Posted June 22, 2023 hello all: I would like to know if there is a routine that does the following: click on any line , and after this be able to draw a line with the same properties (color, linetype, layer, scale) that is, activate the variables of the selected line to draw future lines, polylines or circles. similar to matchprop. Quote Link to comment Share on other sites More sharing options...
Dahzee Posted June 22, 2023 Share Posted June 22, 2023 1 Quote Link to comment Share on other sites More sharing options...
leonucadomi Posted June 22, 2023 Author Share Posted June 22, 2023 I didn't know that command. and it's OK. but i talk about take the properties of the line and adjust the variables, then you can draw lines, polylines ,circles, with the same properties of the parent object (color, linetype, layer, scale). your advice is good. but what i need is similar Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted June 22, 2023 Share Posted June 22, 2023 Are you thinking about an extension of the LAYMCUR command? That one changes the current layer to an object you select. You want to change the current color, linetype, and linetype scale to that object's properties as well as the layer. Is that correct? 1 Quote Link to comment Share on other sites More sharing options...
leonucadomi Posted June 22, 2023 Author Share Posted June 22, 2023 Exactly. is that what you said Quote Link to comment Share on other sites More sharing options...
Tharwat Posted June 22, 2023 Share Posted June 22, 2023 Give this a shot and let me know. (defun c:Test (/ *error* sel get lay clr lty scl var val ) ;;----------------------------------------------------;; ;; Author : Tharwat Al Choufi ;; ;; website: https://autolispprograms.wordpress.com ;; ;;----------------------------------------------------;; (defun *error* (msg) (and val (mapcar 'setvar var val)) (if (and msg (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ "\n*Cancel*")) (princ (strcat "\nError => " msg))) ) (if (and (setq sel (car (entsel "\nSelect object to get properties from : "))) (setq get (entget sel) lay (cdr (assoc 8 get)) ) (or (/= 4 (logand 4 (cdr (assoc 70 (entget (tblobjname "LAYER" lay)))))) (alert "Object resides on locked layer!. Try again") ) (setq clr (cond ((cdr (assoc 62 get))) (256))) (setq lty (cond ((cdr (assoc 06 get))) ("ByLayer"))) (setq scl (cond ((cdr (assoc 48 get))) (1.0))) (setq var '(CECOLOR CELTYPE CLAYER) val (mapcar 'getvar var) ) (mapcar 'setvar var (list (itoa clr) lty lay)) ) (progn (vl-cmdf "_.LINE") (while (= (getvar 'CMDACTIVE) 1) (entmod (append (entget (entlast)) (list (cons 48 scl)))) (vl-cmdf "\\")) ) ) (*error* nil) (princ) ) 1 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 22, 2023 Share Posted June 22, 2023 Another way is draw an object with predefined settings layer, linetype, color etc. So would have some shortcuts like B1, B2 to draw beams with correct settings. We also had a group of lines with predefined set up, and would just paste to the edge of our project so using say Tharwat code they are all available. Ps saved in a layout not model so would use Ctrl+X to cut then go to model and paste Ctrl+V. 1 Quote Link to comment Share on other sites More sharing options...
Tsuky Posted June 23, 2023 Share Posted June 23, 2023 This command allows you to clone a command from an entity already placed in the drawing. Use: Run the DYN_CLONE command Move the cursor over an entity in the drawing: The name of the entity appears in the status bar, instead of the coordinates. If this entity suits you, validate with a right-click and the appropriate command will be launched, taking up its properties (defun c:dyn_clone ( / sv_shmnu loop key ent dxf_ent nam_bl typ_ent lay_ent lin_ent col_ent wid_ent sct_ent flag tabl_dxf cmd_clone) (setq sv_shmnu (getvar "SHORTCUTMENU") loop 0 ) (setvar "SHORTCUTMENU" 11) (while (and (setq key (grread T 4 0)) (not (member key '((2 13) (2 32)))) (/= (car key) 25)) (cond ((and (eq (car key) 3) ent) (setq loop (rem (1+ loop) 2)) ) (T (setq ent (nentselp "" (cadr key))) ) ) (cond ((and ent (zerop loop)) (if (eq (type (car (last ent))) 'ENAME) (setq dxf_ent (entget (car (last ent))) nam_bl (cdr (assoc 2 dxf_ent)) ) (setq dxf_ent (entget (car ent)) nam_bl nil) ) (if (member (cdr (assoc 0 dxf_ent)) '("VERTEX" "ATTRIB")) (progn (setq dxf_ent (entget (cdr (assoc 330 dxf_ent)))) (if (assoc 2 dxf_ent) (setq nam_bl (cdr (assoc 2 dxf_ent)))) ) ) (setq typ_ent (cdr (assoc 0 dxf_ent)) lay_ent (cdr (assoc 8 dxf_ent)) lin_ent (cdr (assoc 6 dxf_ent)) col_ent (cdr (assoc 62 dxf_ent)) wid_ent (cdr (assoc 370 dxf_ent)) sct_ent (cdr (assoc 48 dxf_ent)) ) (grtext -2 typ_ent) ) ) ) (cond ((eq typ_ent "LWPOLYLINE") (setq typ_ent "PLINE") (if (assoc 43 dxf_ent) (setvar "PLINEWID" (cdr (assoc 43 dxf_ent))) (setvar "PLINEWID" (if (equal (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 40)) dxf_ent)) (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 41)) dxf_ent)) ) (* 0.5 (+ (cdr (assoc 40 dxf_ent)) (cdr (assoc 40 dxf_ent)))) 0.0 ) ) ) ) ((eq typ_ent "POLYLINE") (setq flag (rem (cdr (assoc 70 dxf_ent)) 128)) (cond ((< flag 6) (setq typ_ent "PLINE") (setvar "PLINEWID" (if (equal (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 40)) dxf_ent)) (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 41)) dxf_ent)) ) (* 0.5 (+ (cdr (assoc 40 dxf_ent)) (cdr (assoc 40 dxf_ent)))) 0.0 ) ) ) ((and (> flag 7) (< flag 14)) (setq typ_ent "3DPOLY") ) ((> flag 15) (setq typ_ent "3DMESH") ) ) ) ((or (eq typ_ent "HATCH") (eq typ_ent "SHAPE")) (setq nam_bl (cdr (assoc 2 dxf_ent))) ) ((eq typ_ent "DIMENSION") (setq nam_bl nil) (command "_.-dimstyle" "_restore" (cdr (assoc 3 dxf_ent))) (cond ((eq (boole 6 (rem (cdr (assoc 70 dxf_ent)) 128) 32) 0) (setq typ_ent "DIMLINEAR") ) ((eq (boole 6 (rem (cdr (assoc 70 dxf_ent)) 128) 32) 1) (setq typ_ent "DIMALIGNED") ) ((or (eq (boole 6 (rem (cdr (assoc 70 dxf_ent)) 128) 32) 2) (eq (boole 6 (rem (cdr (assoc 70 dxf_ent)) 128) 32) 5)) (setq typ_ent "DIMANGULAR") ) ((eq (boole 6 (rem (cdr (assoc 70 dxf_ent)) 128) 32) 3) (setq typ_ent "DIMDIAMETER") ) ((eq (boole 6 (rem (cdr (assoc 70 dxf_ent)) 128) 32) 4) (setq typ_ent "DIMRADIUS") ) ((or (eq (boole 6 (rem (cdr (assoc 70 dxf_ent)) 128) 32) 6) (eq (boole 6 (rem (cdr (assoc 70 dxf_ent)) 128) 32) 70)) (setq typ_ent "DIMORDINATE") ) (T (setq typ_ent "DIM")) ) ) ((eq typ_ent "VIEWPORT") (setq typ_ent "VPORTS") ) ((eq typ_ent "3DSOLID") (initget 1 "BOîte Sphère CYlindre CÔne BIseau Tore _Box Sphere CYlinder COne Wedge Torus") (setq typ_ent (getkword "\n[BOîte/Sphère/CYlindre/CÔne/BIseau/Tore]: ")) ) ((or (eq typ_ent "TEXT") (eq typ_ent "MTEXT") (eq typ_ent "ATTDEF")) (setvar "TEXTSTYLE" (cdr (assoc 7 dxf_ent))) (setvar "TEXTSIZE" (cdr (assoc 40 dxf_ent))) ) ) (grtext -2 "") (setvar "SHORTCUTMENU" sv_shmnu) (cond (typ_ent (setvar "clayer" lay_ent) (if lin_ent (setvar "celtype" lin_ent) (setvar "celtype" "ByLayer")) (if col_ent (setvar "cecolor" (itoa col_ent)) (setvar "cecolor" "256")) (if wid_ent (setvar "celweight" wid_ent) (setvar "celweight" -1)) (if sct_ent (setvar "celtscale" sct_ent) (setvar "celtscale" 1.0)) (setq cmd_clone (strcat "_." typ_ent)) (if nam_bl (progn (if (and (setq tabl_dxf (tblsearch "BLOCK" nam_bl)) (eq (boole 1 (cdr (assoc 70 tabl_dxf)) 4) 4)) (command "_.-XREF" "_attach" nam_bl) (command cmd_clone nam_bl) ) ) (command cmd_clone) ) ) (T (prin1)) ) ) 1 Quote Link to comment Share on other sites More sharing options...
leonucadomi Posted June 23, 2023 Author Share Posted June 23, 2023 14 hours ago, BIGAL said: Another way is draw an object with predefined settings layer, linetype, color etc. So would have some shortcuts like B1, B2 to draw beams with correct settings. We also had a group of lines with predefined set up, and would just paste to the edge of our project so using say Tharwat code they are all available. Ps saved in a layout not model so would use Ctrl+X to cut then go to model and paste Ctrl+V. It's a good idea. The problem is that my colleagues don't respect the work order. they do what they want with the layers and the linetypes Quote Link to comment Share on other sites More sharing options...
leonucadomi Posted June 23, 2023 Author Share Posted June 23, 2023 15 hours ago, Tharwat said: Give this a shot and let me know. (defun c:Test (/ *error* sel get lay clr lty scl var val ) ;;----------------------------------------------------;; ;; Author : Tharwat Al Choufi ;; ;; website: https://autolispprograms.wordpress.com ;; ;;----------------------------------------------------;; (defun *error* (msg) (and val (mapcar 'setvar var val)) (if (and msg (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ "\n*Cancel*")) (princ (strcat "\nError => " msg))) ) (if (and (setq sel (car (entsel "\nSelect object to get properties from : "))) (setq get (entget sel) lay (cdr (assoc 8 get)) ) (or (/= 4 (logand 4 (cdr (assoc 70 (entget (tblobjname "LAYER" lay)))))) (alert "Object resides on locked layer!. Try again") ) (setq clr (cond ((cdr (assoc 62 get))) (256))) (setq lty (cond ((cdr (assoc 06 get))) ("ByLayer"))) (setq scl (cond ((cdr (assoc 48 get))) (1.0))) (setq var '(CECOLOR CELTYPE CLAYER) val (mapcar 'getvar var) ) (mapcar 'setvar var (list (itoa clr) lty lay)) ) (progn (vl-cmdf "_.LINE") (while (= (getvar 'CMDACTIVE) 1) (entmod (append (entget (entlast)) (list (cons 48 scl)))) (vl-cmdf "\\")) ) ) (*error* nil) (princ) ) I like this routine, only I won't necessarily draw a line, I want anything to be able to be drawn with that type of line, color and layer. and that these parameters remain Quote Link to comment Share on other sites More sharing options...
leonucadomi Posted June 23, 2023 Author Share Posted June 23, 2023 13 hours ago, Tsuky said: This command allows you to clone a command from an entity already placed in the drawing. Use: Run the DYN_CLONE command Move the cursor over an entity in the drawing: The name of the entity appears in the status bar, instead of the coordinates. If this entity suits you, validate with a right-click and the appropriate command will be launched, taking up its properties (defun c:dyn_clone ( / sv_shmnu loop key ent dxf_ent nam_bl typ_ent lay_ent lin_ent col_ent wid_ent sct_ent flag tabl_dxf cmd_clone) (setq sv_shmnu (getvar "SHORTCUTMENU") loop 0 ) (setvar "SHORTCUTMENU" 11) (while (and (setq key (grread T 4 0)) (not (member key '((2 13) (2 32)))) (/= (car key) 25)) (cond ((and (eq (car key) 3) ent) (setq loop (rem (1+ loop) 2)) ) (T (setq ent (nentselp "" (cadr key))) ) ) (cond ((and ent (zerop loop)) (if (eq (type (car (last ent))) 'ENAME) (setq dxf_ent (entget (car (last ent))) nam_bl (cdr (assoc 2 dxf_ent)) ) (setq dxf_ent (entget (car ent)) nam_bl nil) ) (if (member (cdr (assoc 0 dxf_ent)) '("VERTEX" "ATTRIB")) (progn (setq dxf_ent (entget (cdr (assoc 330 dxf_ent)))) (if (assoc 2 dxf_ent) (setq nam_bl (cdr (assoc 2 dxf_ent)))) ) ) (setq typ_ent (cdr (assoc 0 dxf_ent)) lay_ent (cdr (assoc 8 dxf_ent)) lin_ent (cdr (assoc 6 dxf_ent)) col_ent (cdr (assoc 62 dxf_ent)) wid_ent (cdr (assoc 370 dxf_ent)) sct_ent (cdr (assoc 48 dxf_ent)) ) (grtext -2 typ_ent) ) ) ) (cond ((eq typ_ent "LWPOLYLINE") (setq typ_ent "PLINE") (if (assoc 43 dxf_ent) (setvar "PLINEWID" (cdr (assoc 43 dxf_ent))) (setvar "PLINEWID" (if (equal (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 40)) dxf_ent)) (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 41)) dxf_ent)) ) (* 0.5 (+ (cdr (assoc 40 dxf_ent)) (cdr (assoc 40 dxf_ent)))) 0.0 ) ) ) ) ((eq typ_ent "POLYLINE") (setq flag (rem (cdr (assoc 70 dxf_ent)) 128)) (cond ((< flag 6) (setq typ_ent "PLINE") (setvar "PLINEWID" (if (equal (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 40)) dxf_ent)) (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 41)) dxf_ent)) ) (* 0.5 (+ (cdr (assoc 40 dxf_ent)) (cdr (assoc 40 dxf_ent)))) 0.0 ) ) ) ((and (> flag 7) (< flag 14)) (setq typ_ent "3DPOLY") ) ((> flag 15) (setq typ_ent "3DMESH") ) ) ) ((or (eq typ_ent "HATCH") (eq typ_ent "SHAPE")) (setq nam_bl (cdr (assoc 2 dxf_ent))) ) ((eq typ_ent "DIMENSION") (setq nam_bl nil) (command "_.-dimstyle" "_restore" (cdr (assoc 3 dxf_ent))) (cond ((eq (boole 6 (rem (cdr (assoc 70 dxf_ent)) 128) 32) 0) (setq typ_ent "DIMLINEAR") ) ((eq (boole 6 (rem (cdr (assoc 70 dxf_ent)) 128) 32) 1) (setq typ_ent "DIMALIGNED") ) ((or (eq (boole 6 (rem (cdr (assoc 70 dxf_ent)) 128) 32) 2) (eq (boole 6 (rem (cdr (assoc 70 dxf_ent)) 128) 32) 5)) (setq typ_ent "DIMANGULAR") ) ((eq (boole 6 (rem (cdr (assoc 70 dxf_ent)) 128) 32) 3) (setq typ_ent "DIMDIAMETER") ) ((eq (boole 6 (rem (cdr (assoc 70 dxf_ent)) 128) 32) 4) (setq typ_ent "DIMRADIUS") ) ((or (eq (boole 6 (rem (cdr (assoc 70 dxf_ent)) 128) 32) 6) (eq (boole 6 (rem (cdr (assoc 70 dxf_ent)) 128) 32) 70)) (setq typ_ent "DIMORDINATE") ) (T (setq typ_ent "DIM")) ) ) ((eq typ_ent "VIEWPORT") (setq typ_ent "VPORTS") ) ((eq typ_ent "3DSOLID") (initget 1 "BOîte Sphère CYlindre CÔne BIseau Tore _Box Sphere CYlinder COne Wedge Torus") (setq typ_ent (getkword "\n[BOîte/Sphère/CYlindre/CÔne/BIseau/Tore]: ")) ) ((or (eq typ_ent "TEXT") (eq typ_ent "MTEXT") (eq typ_ent "ATTDEF")) (setvar "TEXTSTYLE" (cdr (assoc 7 dxf_ent))) (setvar "TEXTSIZE" (cdr (assoc 40 dxf_ent))) ) ) (grtext -2 "") (setvar "SHORTCUTMENU" sv_shmnu) (cond (typ_ent (setvar "clayer" lay_ent) (if lin_ent (setvar "celtype" lin_ent) (setvar "celtype" "ByLayer")) (if col_ent (setvar "cecolor" (itoa col_ent)) (setvar "cecolor" "256")) (if wid_ent (setvar "celweight" wid_ent) (setvar "celweight" -1)) (if sct_ent (setvar "celtscale" sct_ent) (setvar "celtscale" 1.0)) (setq cmd_clone (strcat "_." typ_ent)) (if nam_bl (progn (if (and (setq tabl_dxf (tblsearch "BLOCK" nam_bl)) (eq (boole 1 (cdr (assoc 70 tabl_dxf)) 4) 4)) (command "_.-XREF" "_attach" nam_bl) (command cmd_clone nam_bl) ) ) (command cmd_clone) ) ) (T (prin1)) ) ) thank you. I ran it but I didn't know how to use it Quote Link to comment Share on other sites More sharing options...
Tharwat Posted June 23, 2023 Share Posted June 23, 2023 16 minutes ago, leonucadomi said: I like this routine, only I won't necessarily draw a line, I want anything to be able to be drawn with that type of line, color and layer. and that these parameters remain I did not see your 'like' !. 1 Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted June 23, 2023 Share Posted June 23, 2023 Why not just use ADDSELECTED command and Cancel when it starts to draw... @Dahzeealready suggested it, but you neglected it... 1 Quote Link to comment Share on other sites More sharing options...
leonucadomi Posted June 23, 2023 Author Share Posted June 23, 2023 38 minutes ago, marko_ribar said: Why not just use ADDSELECTED command and Cancel when it starts to draw... @Dahzeealready suggested it, but you neglected it... if i use that command and select a line (example) I can only draw a line. if i use that command and select a circle (example) I can only draw a circle. and what I want is... select a line (example) I can only draw a line, circle, arc or polyline with the same object properties (color,linetype,layer). and so that those parameters remain pre-established until I select another (different) line and can do the same. something similar to LAYMCUR Quote Link to comment Share on other sites More sharing options...
Tsuky Posted June 23, 2023 Share Posted June 23, 2023 Quote @leonucadomi thank you. I ran it but I didn't know how to use it Run the command With the cursor wander over an entity already drawn. When the cursor passes over an entity its type appears on the status bar (instead of the display of coordinates) If it is this type of entity that you want to reproduce, validate with the right-click The appropriate drawing command will then be launched with the same properties. I can't explain anymore... Launch and watch the taskbar. 1 Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted June 23, 2023 Share Posted June 23, 2023 (edited) No, it won't work with ADDSELECTED + Cancel, but I've prepared something for you : (defun c:cc ( / LM:cecolorfromentity LM:true->rgb KGA_Sys_Transparency_Num_To_Perc KGA_Sys_Transparency_Perc_To_Num s e ex lay ) ;; CECOLOR from Entity - Lee Mac (defun LM:cecolorfromentity ( ent / enx tmp ) (setvar 'cecolor (cond ( (cdr (assoc 430 (setq enx (entget ent)))) ) ( (setq tmp (cdr (assoc 420 enx))) (apply 'strcat (mapcar '(lambda ( a b ) (strcat a (itoa b))) '("RGB:" "," ",") (LM:true->rgb tmp))) ) ( (null (setq tmp (cdr (assoc 62 enx)))) "BYLAYER" ) ( (zerop tmp) "BYBLOCK" ) ( (itoa tmp) ) ) ) ) ;; True -> RGB - Lee Mac ;; Args: c - [int] True Colour (defun LM:true->rgb ( c ) (mapcar '(lambda ( x ) (lsh (lsh (fix c) x) -24)) '(8 16 24)) ) ; (KGA_Sys_Transparency_Num_To_Perc 33554661) => 0.1 (= 10%) ; (KGA_Sys_Transparency_Num_To_Perc (cdr (assoc 440 (entget (car (entsel)))))) (defun KGA_Sys_Transparency_Num_To_Perc ( num ) (* 0.01 (fix (/ (- 33554687 num) 2.55))) ) ; (KGA_Sys_Transparency_Perc_To_Num 0.1) => 33554661 (defun KGA_Sys_Transparency_Perc_To_Num ( perc ) (fix (- 33554687 (* perc 255))) ) (prompt "\nPick source entity with desired layer, linetype, ltscale, lweight, transparency and color for current new usage...") (setq s (ssget "_+.:E:S")) (while (not s) (prompt "\nMissed... Try picking source entity with desired layer, linetype, ltscale, lweight, transparency and color for current new usage again...") (setq s (ssget "_+.:E:S")) ) (if (/= 4 (logand 4 (cdr (assoc 70 (tblsearch "LAYER" (setq lay (cdr (assoc 8 (setq ex (entget (setq e (ssname s 0)))))))))))) (setvar 'clayer lay) ) (if (assoc 6 ex) (setvar 'celtype (cdr (assoc 6 ex))) ) (if (assoc 48 ex) (setvar 'celtscale (cdr (assoc 48 ex))) ) (if (assoc 370 ex) (setvar 'celweight (cdr (assoc 370 ex))) ) (if (assoc 440 ex) (setvar 'cetransparency (* 100 (KGA_Sys_Transparency_Num_To_Perc (cdr (assoc 440 ex))))) (setvar 'cetransparency 0) ) (LM:cecolorfromentity e) (princ) ) HTH. M.R. Edited June 24, 2023 by marko_ribar 1 Quote Link to comment Share on other sites More sharing options...
leonucadomi Posted June 26, 2023 Author Share Posted June 26, 2023 On 6/23/2023 at 3:25 PM, marko_ribar said: No, it won't work with ADDSELECTED + Cancel, but I've prepared something for you : (defun c:cc ( / LM:cecolorfromentity LM:true->rgb KGA_Sys_Transparency_Num_To_Perc KGA_Sys_Transparency_Perc_To_Num s e ex lay ) ;; CECOLOR from Entity - Lee Mac (defun LM:cecolorfromentity ( ent / enx tmp ) (setvar 'cecolor (cond ( (cdr (assoc 430 (setq enx (entget ent)))) ) ( (setq tmp (cdr (assoc 420 enx))) (apply 'strcat (mapcar '(lambda ( a b ) (strcat a (itoa b))) '("RGB:" "," ",") (LM:true->rgb tmp))) ) ( (null (setq tmp (cdr (assoc 62 enx)))) "BYLAYER" ) ( (zerop tmp) "BYBLOCK" ) ( (itoa tmp) ) ) ) ) ;; True -> RGB - Lee Mac ;; Args: c - [int] True Colour (defun LM:true->rgb ( c ) (mapcar '(lambda ( x ) (lsh (lsh (fix c) x) -24)) '(8 16 24)) ) ; (KGA_Sys_Transparency_Num_To_Perc 33554661) => 0.1 (= 10%) ; (KGA_Sys_Transparency_Num_To_Perc (cdr (assoc 440 (entget (car (entsel)))))) (defun KGA_Sys_Transparency_Num_To_Perc ( num ) (* 0.01 (fix (/ (- 33554687 num) 2.55))) ) ; (KGA_Sys_Transparency_Perc_To_Num 0.1) => 33554661 (defun KGA_Sys_Transparency_Perc_To_Num ( perc ) (fix (- 33554687 (* perc 255))) ) (prompt "\nPick source entity with desired layer, linetype, ltscale, lweight, transparency and color for current new usage...") (setq s (ssget "_+.:E:S")) (while (not s) (prompt "\nMissed... Try picking source entity with desired layer, linetype, ltscale, lweight, transparency and color for current new usage again...") (setq s (ssget "_+.:E:S")) ) (if (/= 4 (logand 4 (cdr (assoc 70 (tblsearch "LAYER" (setq lay (cdr (assoc 8 (setq ex (entget (setq e (ssname s 0)))))))))))) (setvar 'clayer lay) ) (if (assoc 6 ex) (setvar 'celtype (cdr (assoc 6 ex))) ) (if (assoc 48 ex) (setvar 'celtscale (cdr (assoc 48 ex))) ) (if (assoc 370 ex) (setvar 'celweight (cdr (assoc 370 ex))) ) (if (assoc 440 ex) (setvar 'cetransparency (* 100 (KGA_Sys_Transparency_Num_To_Perc (cdr (assoc 440 ex))))) (setvar 'cetransparency 0) ) (LM:cecolorfromentity e) (princ) ) HTH. M.R. brilliant. It's exactly what I need. thank you Quote Link to comment Share on other sites More sharing options...
leonucadomi Posted June 26, 2023 Author Share Posted June 26, 2023 On 6/23/2023 at 3:25 PM, marko_ribar said: No, it won't work with ADDSELECTED + Cancel, but I've prepared something for you : (defun c:cc ( / LM:cecolorfromentity LM:true->rgb KGA_Sys_Transparency_Num_To_Perc KGA_Sys_Transparency_Perc_To_Num s e ex lay ) ;; CECOLOR from Entity - Lee Mac (defun LM:cecolorfromentity ( ent / enx tmp ) (setvar 'cecolor (cond ( (cdr (assoc 430 (setq enx (entget ent)))) ) ( (setq tmp (cdr (assoc 420 enx))) (apply 'strcat (mapcar '(lambda ( a b ) (strcat a (itoa b))) '("RGB:" "," ",") (LM:true->rgb tmp))) ) ( (null (setq tmp (cdr (assoc 62 enx)))) "BYLAYER" ) ( (zerop tmp) "BYBLOCK" ) ( (itoa tmp) ) ) ) ) ;; True -> RGB - Lee Mac ;; Args: c - [int] True Colour (defun LM:true->rgb ( c ) (mapcar '(lambda ( x ) (lsh (lsh (fix c) x) -24)) '(8 16 24)) ) ; (KGA_Sys_Transparency_Num_To_Perc 33554661) => 0.1 (= 10%) ; (KGA_Sys_Transparency_Num_To_Perc (cdr (assoc 440 (entget (car (entsel)))))) (defun KGA_Sys_Transparency_Num_To_Perc ( num ) (* 0.01 (fix (/ (- 33554687 num) 2.55))) ) ; (KGA_Sys_Transparency_Perc_To_Num 0.1) => 33554661 (defun KGA_Sys_Transparency_Perc_To_Num ( perc ) (fix (- 33554687 (* perc 255))) ) (prompt "\nPick source entity with desired layer, linetype, ltscale, lweight, transparency and color for current new usage...") (setq s (ssget "_+.:E:S")) (while (not s) (prompt "\nMissed... Try picking source entity with desired layer, linetype, ltscale, lweight, transparency and color for current new usage again...") (setq s (ssget "_+.:E:S")) ) (if (/= 4 (logand 4 (cdr (assoc 70 (tblsearch "LAYER" (setq lay (cdr (assoc 8 (setq ex (entget (setq e (ssname s 0)))))))))))) (setvar 'clayer lay) ) (if (assoc 6 ex) (setvar 'celtype (cdr (assoc 6 ex))) ) (if (assoc 48 ex) (setvar 'celtscale (cdr (assoc 48 ex))) ) (if (assoc 370 ex) (setvar 'celweight (cdr (assoc 370 ex))) ) (if (assoc 440 ex) (setvar 'cetransparency (* 100 (KGA_Sys_Transparency_Num_To_Perc (cdr (assoc 440 ex))))) (setvar 'cetransparency 0) ) (LM:cecolorfromentity e) (princ) ) HTH. M.R. I already tried it and it works, but it has a problem if the origin line is "bylayer" does not change the linetype Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 27, 2023 Share Posted June 27, 2023 Somewhere had create a object based on pick which is what you want, try this can add more properties. ; matches pick object for next command plus layer ; created 2011 ; sorry no author (defun c:ZZZ (/ ent Obj lEnt) (vl-load-com) (while (setq ent (car (nentsel "\nSelect Object: "))) (setq Obj (vlax-ename->vla-object ent) typ (cdr (assoc 0 (entget ent)))) (cond ((vl-position typ '("CIRCLE" "ARC" "ELLIPSE" "SPLINE" "XLINE")) (comInv typ nil) (PropMatch Obj (entlast))) ((eq "LWPOLYLINE" typ) (comInv "pline" nil) (PropMatch Obj (entlast))) ((eq "LINE" typ) (setq lEnt (entlast)) (comInv typ nil) (foreach ent (EntCol (if lEnt lEnt (entlast))) (PropMatch Obj ent))) ((eq "HATCH" typ) (setq lEnt (entlast)) (comInv typ t) (if (not (eq lEnt (entlast))) (PropMatch Obj (entlast)))) ((eq "VIEWPORT" typ) (setq lEnt (entlast)) (comInv "-vports" nil) (if (not (eq lEnt (entlast))) (PropMatch Obj (entlast)))))) (princ)) (defun PropMatch (bObj dObj) (or (eq 'VLA-OBJECT (type bObj)) (setq bObj (vlax-ename->vla-object bObj))) (or (eq 'VLA-OBJECT (type dObj)) (setq dObj (vlax-ename->vla-object dObj))) (foreach prop '(Layer Linetype LinetypeScale Color Lineweight ViewportOn ShadePlot DisplayLocked GradientAngle GradientCentered GradientColor1 GradientColor2 GradientName HatchObjectType HatchStyle ISOPenWidth Origin PatternAngle PatternDouble PatternScale PatternSpace) (if (and (vlax-property-available-p bObj prop) (vlax-property-available-p dObj prop T)) (vlax-put-property dObj prop (vlax-get-property bObj prop))))) (defun EntCol (x / x) (if (setq x (entnext x)) (cons x (EntCol x)))) (defun comInv (com flag) (if flag (initdia)) (command (strcat "_." com)) (while (eq 1 (logand 1 (getvar "CMDACTIVE"))) (command pause))) 1 Quote Link to comment Share on other sites More sharing options...
