Mismatching Problem
I have problem in mismatching the drawing scale.
we received drawing in different scale/dimension and convert the drawing into our standard sacle 1:1250
sometime big drawing has not been matching with our standard scale 1:1250 A1 size.
how it could be match / adjust in our standard scale 1:1250 A1 size ?
Regards
Muhammad
autocad 2008
So your firm drew up the titleblock and border and someone else was responsible for the actual drawing itself? The drawing should be in model space right? What about the titleblock and border? Is it in model space or paper space?
actually, big drawings creating difficulty to adjust the standard scale 1:1250 A1 size , we don't want to cut / divid the the drawings into
two drawings,
we must make the only one drawing which scale should be 1:1250 A1 size.
Regards
Muhammad
autocad 2008
Too bad you didn't answer any of my questions.
there are several answers to your problem depending on specific criteria, so if you answer ReMarks questions, we'll be able to help you
if you don't, we've no idea WHICH answer you require
1, we are responsible for actual drawing also
2, yes, the drawing in model space and we have to adjust in
layout A1 size
3, title block and border also create problem in adjustment
4, paper space, it create problem in adjusting the layout A1 size
Regards
Muhammad
Assuming the objects in model space have been drawn full size you enter paper space and using Page Setup Manager determine the sheet size you'll be plotting to. Once you have done that make a new layer called Vport and on this layer create a single viewport. The viewport is the window through which you look back into model space and see the objects you have drawn there. It is the viewport that is scaled and NOT the objects in model space. Do you understand the concept? Have you used paper space and viewports?
There should be no problem in adjustment with your title block and border IF you drew it full size in paper space. Anything positioned within the dashed lines on your layout will be plotted. You plot from paper space at a scale of 1:1.
