I have a problem: I must copy one block to every text in the drawing. The insert point of block is the same insert point of text. I use copy command to do this work but it to slow.
I want a lisp code to do this work: insert a block to the slection texts, or copy one object to the slection texts. And maybe more: copy one object to the insert point of selection objects.
Thankyou for your help.
Maybe something like this:
[b][color=BLACK]([/color][/b]defun c:txt2ins [b][color=FUCHSIA]([/color][/b]/ bn ss i en ed ip[b][color=FUCHSIA])[/color][/b]
[color=#8b4513];;;GET THE BLOCK[/color]
 [b][color=FUCHSIA]([/color][/b]while [b][color=NAVY]([/color][/b]not bn[b][color=NAVY])[/color][/b]
        [b][color=NAVY]([/color][/b]setq bn [b][color=MAROON]([/color][/b]getstring [color=#2f4f4f]"\nBLOCK To Insert:   "[/color][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
        [b][color=NAVY]([/color][/b]cond [b][color=MAROON]([/color][/b][b][color=GREEN]([/color][/b]and [b][color=BLUE]([/color][/b]snvalid bn[b][color=BLUE])[/color][/b]
                    [b][color=BLUE]([/color][/b]tblsearch [color=#2f4f4f]"BLOCK"[/color] bn[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
                    [b][color=BLUE]([/color][/b]findfile [b][color=RED]([/color][/b]strcat bn [color=#2f4f4f]".DWG"[/color][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b]
               [b][color=GREEN]([/color][/b]command [color=#2f4f4f]"_.INSERT"[/color] bn[b][color=GREEN])[/color][/b]
               [b][color=GREEN]([/color][/b]command[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
              [b][color=MAROON]([/color][/b]T [b][color=GREEN]([/color][/b]setq bn nil[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
[color=#8b4513];;;GET THE TEXT[/color]
 [b][color=FUCHSIA]([/color][/b]while [b][color=NAVY]([/color][/b]not ss[b][color=NAVY])[/color][/b]
        [b][color=NAVY]([/color][/b]princ [color=#2f4f4f]"\nSelect TEXT to Insert Blocks To:   "[/color][b][color=NAVY])[/color][/b]
        [b][color=NAVY]([/color][/b]setq ss [b][color=MAROON]([/color][/b]ssget [b][color=GREEN]([/color][/b]list [b][color=BLUE]([/color][/b]cons 0 [color=#2f4f4f]"TEXT"[/color][b][color=BLUE])[/color][/b]
                              [b][color=BLUE]([/color][/b]if [b][color=RED]([/color][/b]getvar [color=#2f4f4f]"CTAB"[/color][b][color=RED])[/color][/b]
                                  [b][color=RED]([/color][/b]cons 410 [b][color=PURPLE]([/color][/b]getvar [color=#2f4f4f]"CTAB"[/color][b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b]
                                  [b][color=RED]([/color][/b]cons 67 [b][color=PURPLE]([/color][/b]- 1 [b][color=TEAL]([/color][/b]getvar [color=#2f4f4f]"TILEMODE"[/color][b][color=TEAL])[/color][/b][b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
       [b][color=NAVY]([/color][/b]setq i [b][color=MAROON]([/color][/b]sslength ss[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
[color=#8b4513];;;INSERT THE BLOCK[/color]
       [b][color=NAVY]([/color][/b]while [b][color=MAROON]([/color][/b]not [b][color=GREEN]([/color][/b]minusp [b][color=BLUE]([/color][/b]setq i [b][color=RED]([/color][/b]1- i[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
              [b][color=MAROON]([/color][/b]setq en [b][color=GREEN]([/color][/b]ssname ss i[b][color=GREEN])[/color][/b]
                    ed [b][color=GREEN]([/color][/b]entget en[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
              [b][color=MAROON]([/color][/b]if [b][color=GREEN]([/color][/b]and [b][color=BLUE]([/color][/b]zerop [b][color=RED]([/color][/b]cdr [b][color=PURPLE]([/color][/b]assoc 71 ed[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b]
                       [b][color=BLUE]([/color][/b]zerop [b][color=RED]([/color][/b]cdr [b][color=PURPLE]([/color][/b]assoc 72 ed[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b]
                       [b][color=BLUE]([/color][/b]zerop [b][color=RED]([/color][/b]cdr [b][color=PURPLE]([/color][/b]assoc 73 ed[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b]
                  [b][color=GREEN]([/color][/b]setq ip [b][color=BLUE]([/color][/b]cdr [b][color=RED]([/color][/b]assoc 10 ed[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b]
                  [b][color=GREEN]([/color][/b]setq ip [b][color=BLUE]([/color][/b]cdr [b][color=RED]([/color][/b]assoc 11 ed[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
              [b][color=MAROON]([/color][/b]command [color=#2f4f4f]"_.INSERT"[/color] bn ip[b][color=MAROON])[/color][/b]
              [b][color=MAROON]([/color][/b]while [b][color=GREEN]([/color][/b]> [b][color=BLUE]([/color][/b]getvar [color=#2f4f4f]"CMDACTIVE"[/color][b][color=BLUE])[/color][/b] 0[b][color=GREEN])[/color][/b]
                     [b][color=GREEN]([/color][/b]command [color=#2f4f4f]""[/color][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
  [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b]
This does not take into account the curent LAYER, ELEVATION, THICKNESS, CELTYPE, UCS or CECOLOR Settings. -David
  • 10 months later...
Thank David.
It work fine with block and texts.
What about "Insert text to every block" ???? If I have many block in the screen, I want to add a string of text to every block. How can I do that with LISP???
Who can show me the code???
Thanks for all.
Try this:
(defun c:txt@ins (/ Make_Text str i ss ent)
 ;; Lee Mac  ~  15.01.10
 (defun Make_Text (pt str)
   (entmakex (list (cons 0 "TEXT")
                   (cons 10 pt)
                   (cons 1 str)
                   (cons 40 (getvar 'TEXTSIZE)))))
 (if (and (setq str     (getstring t "\nSpecify Text String: "))
          (setq i -1 ss (ssget '((0 . "INSERT")))))
   (while (setq ent (ssname ss (setq i (1+ i))))
     (Make_Text (cdr (assoc 10 (entget ent))) str)))
 (princ))
