cedar Posted February 25, 2009 Posted February 25, 2009 Haha, I cheated. I traced a spline around the profile and extruded a surface to mate against. I don’t have that cam program for some reason so I can’t analyze it. Shift said SW wouldn’t make a cam program if it doesn’t work… I’m not so sure. I think SW does release half baked functions. If the sketch in the cam that Fusive posted is the output of the cam program… then I think it was not intended to be used for the finished cam. There are no constraints, no adjustments, why all the little segments if a single arc would work? I tried to put tangent constraints on the sketch segments and it went wacky. Even when I fixed the sketch so all the arcs were tangent… cam mate wouldn’t work. Maybe your cam is too complicated for the cam generator to calculate. All I know for sure is that a single spline works great for cams. And that cam generated sketch can be traced with a spline almost perfect. Quote
shift1313 Posted February 25, 2009 Posted February 25, 2009 well the cam generator worked in a motion study so you can analyze the profile by tracing it and analyze forces etc. Cedar, in the cam generator you can create a very detailed cam. you give it radius, degrees of motion, type of motion etc. The program is very Picky as to what it will let out. Fusive, did you have a spec sheet for what cam values you inputed? how did you determine your cam values? Quote
kelven Posted April 21, 2011 Posted April 21, 2011 Hi, everyone. I have a problem to use the cam mate? pls teach me how to use it. my problem have attach with a photo. Thanks Quote
shift1313 Posted April 22, 2011 Posted April 22, 2011 It looks like either you havent selected all the faces of your path OR you dont have tangency everywhere. When you are selecting the path just right click on one of the faces and "select tangency" and it should select all the faces. If it doesnt you may need to alter the part Quote
