andy_06 Posted July 24, 2023 Posted July 24, 2023 Hi, I am looking for some help and hope this is possible. Attached is a small water network drawing and I would like a routine that automatically selects the node at each end of the polyline when the polyline is selected. I would need it to the work on multiple polylines. An example on the attached would be selecting the 3 x polylines between nodes 1-2-4-5 and then automtically select the 4 x nodes as well. I would then copy and paste these items. I hope this makes sense! TEST.dwg Quote
Tsuky Posted July 24, 2023 Posted July 24, 2023 Hi, I don't know if I understood correctly, but the following may be satisfactory for you. You select all the polylines, then a single polyline (central or not). The selection of polylines having a common vertex or close to a segment will then be selected. (defun compare (l d l_e / prm new_l) (mapcar '(lambda (e) (mapcar '(lambda (x) (setq prm (cond ((equal (cadr x) (vlax-curve-getClosestPointTo e (cadr x) T) d) (vlax-curve-getparamatpoint e (trans (cadr x) e 0)) ) ((equal (last x) (vlax-curve-getClosestPointTo e (last x) T) d) (vlax-curve-getparamatpoint e (trans (last x) e 0)) ) ) ) (if (and prm (not (member (car x) l_e))) (progn (ssadd (car x) ss) (setq new_l (cons (car x) l_e)) ) ) ) l ) ) l_e ) (if new_l new_l nil) ) (defun list_pt_sel (l_e / dxf_ent) (mapcar '(lambda (e) (setq dxf_ent (entget e)) (cons e (mapcar '(lambda (x) (trans x e 0) ) (mapcar 'cdr (vl-remove-if '(lambda (x) (/= (car x) 10) ) dxf_ent ) ) ) ) ) l_e ) ) (defun c:pl_connect ( / dfzz js_all n e_all js_first ss e_master lst_pt_ori e_other lst_pt l) (if (not dfzz) (setq dfzz 1E-08)) (princ "\nSelect polylines") (while (not (setq js_all (ssget '((0 . "LWPOLYLINE")))))) (repeat (setq n (sslength js_all)) (setq e_all (cons (ssname js_all (setq n (1- n))) e_all)) ) (princ "\Select ONE central polyline") (while (not (setq js_first (ssget "_+.:E:S" '((0 . "LWPOLYLINE")))))) (setq ss (ssadd)) (setq e_master (ssname js_first 0)) (setq ss (ssadd e_master ss)) (setq lst_pt_ori (list_pt_sel e_all)) (cond (lst_pt_ori (setq e_other e_all) (setq e_other (vl-remove e_master e_other)) (cond (e_other (setq lst_pt (list_pt_sel e_other)) (setq l (list e_master)) (while l (setq l (compare lst_pt dfzz l)) ) ) ) (sssetfirst nil ss) ) ) ) Quote
andy_06 Posted July 24, 2023 Author Posted July 24, 2023 55 minutes ago, Tsuky said: Hi, I don't know if I understood correctly, but the following may be satisfactory for you. You select all the polylines, then a single polyline (central or not). The selection of polylines having a common vertex or close to a segment will then be selected. (defun compare (l d l_e / prm new_l) (mapcar '(lambda (e) (mapcar '(lambda (x) (setq prm (cond ((equal (cadr x) (vlax-curve-getClosestPointTo e (cadr x) T) d) (vlax-curve-getparamatpoint e (trans (cadr x) e 0)) ) ((equal (last x) (vlax-curve-getClosestPointTo e (last x) T) d) (vlax-curve-getparamatpoint e (trans (last x) e 0)) ) ) ) (if (and prm (not (member (car x) l_e))) (progn (ssadd (car x) ss) (setq new_l (cons (car x) l_e)) ) ) ) l ) ) l_e ) (if new_l new_l nil) ) (defun list_pt_sel (l_e / dxf_ent) (mapcar '(lambda (e) (setq dxf_ent (entget e)) (cons e (mapcar '(lambda (x) (trans x e 0) ) (mapcar 'cdr (vl-remove-if '(lambda (x) (/= (car x) 10) ) dxf_ent ) ) ) ) ) l_e ) ) (defun c:pl_connect ( / dfzz js_all n e_all js_first ss e_master lst_pt_ori e_other lst_pt l) (if (not dfzz) (setq dfzz 1E-08)) (princ "\nSelect polylines") (while (not (setq js_all (ssget '((0 . "LWPOLYLINE")))))) (repeat (setq n (sslength js_all)) (setq e_all (cons (ssname js_all (setq n (1- n))) e_all)) ) (princ "\Select ONE central polyline") (while (not (setq js_first (ssget "_+.:E:S" '((0 . "LWPOLYLINE")))))) (setq ss (ssadd)) (setq e_master (ssname js_first 0)) (setq ss (ssadd e_master ss)) (setq lst_pt_ori (list_pt_sel e_all)) (cond (lst_pt_ori (setq e_other e_all) (setq e_other (vl-remove e_master e_other)) (cond (e_other (setq lst_pt (list_pt_sel e_other)) (setq l (list e_master)) (while l (setq l (compare lst_pt dfzz l)) ) ) ) (sssetfirst nil ss) ) ) ) Thank you for looking at this for me. Sorry I am a complete novice, I know how to load the LISP file but usually the files I can used give a command prompt to use in CAD. How do I add this? Quote
Tsuky Posted July 24, 2023 Posted July 24, 2023 (defun compare) and (defun list_pt_sel) are functions used in (defun c:pl_connect) wich is the command function. The command is PL_CONNECT Quote
andy_06 Posted July 25, 2023 Author Posted July 25, 2023 17 hours ago, Tsuky said: (defun compare) and (defun list_pt_sel) are functions used in (defun c:pl_connect) wich is the command function. The command is PL_CONNECT Thank you for this! It nearly does what I require but could it also select the nodes as well as each polyline? Quote
Tsuky Posted July 25, 2023 Posted July 25, 2023 12 hours ago, andy_06 said: Thank you for this! It nearly does what I require but could it also select the nodes as well as each polyline? This can be to resolve it? (defun compare (l l_b d l_e / prm new_l) (mapcar '(lambda (e) (mapcar '(lambda (x) (setq prm (cond ((equal (cadr x) (vlax-curve-getClosestPointTo e (cadr x) T) d) (vlax-curve-getparamatpoint e (trans (cadr x) e 0)) ) ((equal (last x) (vlax-curve-getClosestPointTo e (last x) T) d) (vlax-curve-getparamatpoint e (trans (last x) e 0)) ) ) ) (if (and prm (not (member (car x) l_e))) (progn (ssadd (car x) ss) (setq new_l (cons (car x) l_e)) (mapcar '(lambda (xb) (cond ((or (equal (cadr x) (trans (cadr xb) (car xb) 0) d) (equal (last x) (trans (cadr xb) (car xb) 0) d) ) (ssadd (car xb) ss) ) ) ) l_b ) ) ) ) l ) ) l_e ) (if new_l new_l nil) ) (defun list_pt_sel (l_e / dxf_ent) (mapcar '(lambda (e) (setq dxf_ent (entget e)) (cons e (mapcar '(lambda (x) (trans x e 0) ) (mapcar 'cdr (vl-remove-if '(lambda (x) (/= (car x) 10) ) dxf_ent ) ) ) ) ) l_e ) ) (defun c:pl_connect ( / dfzz js_all n e_all js_first ss e_master lst_pt_ori e_other lst_pt l js_blk e_blk lst_pt_blk) (if (not dfzz) (setq dfzz 1E-08)) (princ "\nSelect polylines") (while (not (setq js_all (ssget '((0 . "LWPOLYLINE")))))) (repeat (setq n (sslength js_all)) (setq e_all (cons (ssname js_all (setq n (1- n))) e_all)) ) (princ "\Select ONE central polyline") (while (not (setq js_first (ssget "_+.:E:S" '((0 . "LWPOLYLINE")))))) (setq ss (ssadd)) (setq e_master (ssname js_first 0)) (setq ss (ssadd e_master ss)) (setq lst_pt_ori (list_pt_sel e_all)) (cond (lst_pt_ori (setq e_other e_all) (setq e_other (vl-remove e_master e_other)) (cond (e_other (setq lst_pt (list_pt_sel e_other) l (list e_master) js_blk (ssget "_X" '((0 . "INSERT") (8 . "0water nodes") (2 . "GNW"))) ) (repeat (setq n (sslength js_blk)) (setq e_blk (cons (ssname js_blk (setq n (1- n))) e_blk)) ) (setq lst_pt_blk (list_pt_sel e_blk)) (while l (setq l (compare lst_pt lst_pt_blk dfzz l)) ) ) ) (sssetfirst nil ss) ) ) ) Quote
andy_06 Posted July 26, 2023 Author Posted July 26, 2023 10 hours ago, Tsuky said: This can be to resolve it? (defun compare (l l_b d l_e / prm new_l) (mapcar '(lambda (e) (mapcar '(lambda (x) (setq prm (cond ((equal (cadr x) (vlax-curve-getClosestPointTo e (cadr x) T) d) (vlax-curve-getparamatpoint e (trans (cadr x) e 0)) ) ((equal (last x) (vlax-curve-getClosestPointTo e (last x) T) d) (vlax-curve-getparamatpoint e (trans (last x) e 0)) ) ) ) (if (and prm (not (member (car x) l_e))) (progn (ssadd (car x) ss) (setq new_l (cons (car x) l_e)) (mapcar '(lambda (xb) (cond ((or (equal (cadr x) (trans (cadr xb) (car xb) 0) d) (equal (last x) (trans (cadr xb) (car xb) 0) d) ) (ssadd (car xb) ss) ) ) ) l_b ) ) ) ) l ) ) l_e ) (if new_l new_l nil) ) (defun list_pt_sel (l_e / dxf_ent) (mapcar '(lambda (e) (setq dxf_ent (entget e)) (cons e (mapcar '(lambda (x) (trans x e 0) ) (mapcar 'cdr (vl-remove-if '(lambda (x) (/= (car x) 10) ) dxf_ent ) ) ) ) ) l_e ) ) (defun c:pl_connect ( / dfzz js_all n e_all js_first ss e_master lst_pt_ori e_other lst_pt l js_blk e_blk lst_pt_blk) (if (not dfzz) (setq dfzz 1E-08)) (princ "\nSelect polylines") (while (not (setq js_all (ssget '((0 . "LWPOLYLINE")))))) (repeat (setq n (sslength js_all)) (setq e_all (cons (ssname js_all (setq n (1- n))) e_all)) ) (princ "\Select ONE central polyline") (while (not (setq js_first (ssget "_+.:E:S" '((0 . "LWPOLYLINE")))))) (setq ss (ssadd)) (setq e_master (ssname js_first 0)) (setq ss (ssadd e_master ss)) (setq lst_pt_ori (list_pt_sel e_all)) (cond (lst_pt_ori (setq e_other e_all) (setq e_other (vl-remove e_master e_other)) (cond (e_other (setq lst_pt (list_pt_sel e_other) l (list e_master) js_blk (ssget "_X" '((0 . "INSERT") (8 . "0water nodes") (2 . "GNW"))) ) (repeat (setq n (sslength js_blk)) (setq e_blk (cons (ssname js_blk (setq n (1- n))) e_blk)) ) (setq lst_pt_blk (list_pt_sel e_blk)) (while l (setq l (compare lst_pt lst_pt_blk dfzz l)) ) ) ) (sssetfirst nil ss) ) ) ) Wow that is brilliant! Only one minor thing and that is it doesn't select the end node so is it possible to add this? I selected nodes 1-2-4-5 and it did everything I required apart from picking up node 5. Quote
Tsuky Posted July 26, 2023 Posted July 26, 2023 3 hours ago, andy_06 said: Wow that is brilliant! Only one minor thing and that is it doesn't select the end node so is it possible to add this? I selected nodes 1-2-4-5 and it did everything I required apart from picking up node 5. Indeed, I have to constat your comment. However, following the single selection of the central polyline, the result is different: If the selection of the central polyline is included between other segments the result is correct. If the center polyline selection has no connection at one either end; an end block is omitted. Honestly I don't know if I would be able to solve this problem... Quote
