ya no funciona la rutina
Encontré la rutina en la red y funcionaba bien, despues de varios años quise volver a usarla y ya no funciona
(defun c:cs ()
  (setvar "osmode" 0)
  (setvar "osmode" 32)
  ;(setvar "cmddia" 0)
                           (if (= nil estac) (setq estac 0.00) (setq estac (+ estac 20.00)))
                           (setq cad (strcat "Estacion?< " (rtos estac 2 2) ">:"))
                           (setq estacion (getreal cad))
                     (if (/= estacion nil) ;(setq estac (+ 20 estac))
                             (setq estac estacion)
                           (setq Pref (getpoint "\nPunto de referencia: "))
                          (SETQ pX(CAR pref) pY(CAR (CDR pref)))
                           (SETQ Pto (GETPOINT "\nPunto para cero:"))
        (while (/= nil PTO)
                         (SETQ X1(CAR pto) Y1(CAR (CDR pto)))
                         (setq dist (- y1 py))
                                   (command "-insert" "cero" pto "" "" ""
                                   (rtos estac 2 3)
                                   (rtos dist 2 3)
                           (SETQ Pto (GETPOINT "\nNuevo Punto para cero:"))
;(setvar "cmddia" 1)
Our new friend complains that this Lisp doesn't work any more, after it worked well years ago.
con las nuevas variables del sistema de instalación es lo más probable por qué no funciona ahora.
(defun c:cs ()
  (setvar "osmode" 0)
        (while (/= nil PTO)
                                   (rtos estac 2 3)
                                   (rtos dist 2 3)
@GENARO PEREZ CHENG  Por favor sube el dwg donde aplicas el lisp y copia la pantalla de texto donde se ve el error.
 (command "-insert" "cero"~~
In this statement, the cero block is inserted with the -insert function,
it won't work if cero is not in the dwg's blocklist.
I guess A few years ago you worked on a drawing with a block "cero", and now you're working on a drawing that doesn't have.
