Rev Clouds...Is there a difference?
...between a standard/normal style or the calligraphy style?
Does the calligraphy style mean anything or is it just personal preference as to which looks best?:unsure:
Andy
Normal style uses a single lineweight for the arcs. Calligraphy style assigns the arcs a variable lineweight from thin to thick (left to right). It's all a matter of personal taste.
Calligraphy style does look better but i was unsure wether to use it incase it meant something i didnt know.
I think you MUST consider Client Cad Standard (if they have one)and Company CAD Standard...then personal taste. lol
peace out
The calligraphy style just calls attention to itself a bit more. However, this can be done in normal style too just by assigning a constant width (like a polyline) to the cloud. Then it will stand out with no problem.
Most clients don't give two hoots about what the "cloud" looks like. Why? Because it is a cloud. It's so different from almost everything else on the drawing (with the exception of a treeline) that it is immediately noticeable.
