Mystogan Posted August 9, 2023 Posted August 9, 2023 Hi Hoping someone could help me to create a lsp that make all the selected block change into layer 0 and also the properties into By layer. I try this one https://www.cadtutor.net/forum/topic/73427-lisp-to-change-layer-to-nest-objects-inside-block-putting-them-on-block-layer/ But it didn't work I got an automation error. The drawing is in color dependent plot style mode. There two types of block one is dynamic and regular, I hope it will be applicable for both type. Quote
ronjonp Posted August 9, 2023 Posted August 9, 2023 (edited) 23 hours ago, Mystogan said: Hi Hoping someone could help me to create a lsp that make all the selected block change into layer 0 and also the properties into By layer. I try this one https://www.cadtutor.net/forum/topic/73427-lisp-to-change-layer-to-nest-objects-inside-block-putting-them-on-block-layer/ But it didn't work I got an automation error. The drawing is in color dependent plot style mode. There two types of block one is dynamic and regular, I hope it will be applicable for both type. Try the code here: http://www.theswamp.org/index.php?topic=3020.msg37746#msg37746 Edited August 10, 2023 by ronjonp Quote
Mystogan Posted August 10, 2023 Author Posted August 10, 2023 Hi ronjonp thank you, I found the right for me. It was done by: David Bethel Here's the code (defun c:upb (/ tdef fe ed) (while (setq tdef (tblnext "BLOCK" (not tdef))) (princ (strcat "\n" (strcase (cdr (assoc 2 tdef))))) (setq fe (cdr (assoc -2 tdef))) (while fe (setq ed (entget fe) ed (subst '(8 . "0") (assoc 8 ed) ed) ed (if (assoc 62 ed) (subst '(62 . 256) (assoc 62 ed) ed) (append ed '((62 . 256))))) (entmod ed) (setq fe (entnext fe)))) (prin1)) Quote
