This has probably already been dealt with in the past but I can't find a post that helps me in this particular situation.
I have a DXF file from an external source where all the blocks come into my drawing named "diag_cross".
I would like to redefine the blocks but on a layer-dependant basis.
For example, If the layer was named "757_TAP" then the redefine would need to be "diag_cross=tap" where ACAD would call file "tap".
However, as redefine is a global statement, I need to be able to select as layer-name dependant.
Ideally this would be an automated process if possible, rather than by selection.
Is the original dwg made from field survey ? If so way better to go back a few steps, CIV3D and for me Civil Site Design support read a field survey code and insert correct block on the point as well as stringing.
Well, you can't call a block "diag_cross=tap".  No special characters (except a few).
You can redefine the blockname of inserted blocks; that's no problem.
Here's a test example:
(defun rename_blockname (blockname newblockname  / blklst)
	(vl-load-com)
	(setq blklst (vla-get-Blocks (vla-get-activedocument (vlax-get-acad-object))))
	(vla-put-Name (vla-item blklst blockname) newblockname)
(defun c:rdb ( / ss i blockname newblockname)
	(if (or (setq ss (ssget '((0 . "INSERT")))) (setq ss (ssget "_X" '((0 . "INSERT")))))
			(setq i 0)
			(repeat (sslength ss)
				(rename_blockname
					(setq blockname (cdr (assoc 2 (entget (ssname ss i)))))
					(setq newblockname (getstring (strcat "Block: " blockname ", set new name: ")))
				(setq i (+ i 1))
But I'm not sure what exactly you want.
