Aftertouch Posted August 14, 2023 Posted August 14, 2023 (edited) Hi all, Â Is there a way to turn on the 'Plot Transpacency' for the active layout? All LISP solutions i find, either do not work, or manipulate the PLOTTRANSPARENYOVERRIDE value to 2. Â Other solutions only work for the model space and not the active layout. Â Â EDIT: Sorry, solved it! Â (setq xData (vlax-make-safearray vlax-vbVariant '(0 . 1))) (setq xType (vlax-make-safearray vlax-vbInteger '(0 . 1))) (vlax-safearray-fill xData (list (vlax-make-variant "PLOTTRANSPARENCY")(vlax-make-variant 1))) (vlax-safearray-fill xType (list 1001 1071)) (vla-setXdata (vla-item layouts (getvar "CTAB")) xType xData) (entmod (entget (vlax-vla-object->ename (vla-item layouts (getvar "CTAB"))) '("*"))) Â Edited August 14, 2023 by Aftertouch Quote
BIGAL Posted August 14, 2023 Posted August 14, 2023 Maybe something like this (setvar "textfill" 1) (setvar "fillmode" 1) (setvar "PLOTTRANSPARENCYOVERRIDE" 2) (COMMAND "-PLOT" "Y" "" "dwg to Pdf" "Iso full bleed A3 (420.00 x 297.00 MM)" "m" "LANDSCAPE" "N" "W" "-6,-6" "807,560" "1=2" "C" "y" "Acad.ctb" "Y" "n" "n" "n" pdfName "N" "y" ) Â Quote
