hatch is only visible when cursor is over it...?
I am hatching a simple closed triangle. I'm using predetermined, solid, and by-layer. I then select the object and hit OK.
At that point, the object shows being hatched, but the hatch only shows up when I hover the cursor over it. I can select the hatch and everything seems normal, but when I deselect it, I can no longer see the hatch. It acts as if the draw order is hiding the hatch, however, I've tried to change the draw order and that didn't fix the problem.
Thanks, HF
Additionally, I am able to properly hatch with other patterns, just not with a solid pattern...
Wild guess. Is Fillmode set to "0" instead of "1"?
Fillmode was already at "1". Same problem.
