Kaner65 Posted February 23, 2009 Posted February 23, 2009 I heard that it was possible to generate a roof plan with just a plan outline assuming the same eave heights all the way around the perimeter. I had never heard of that before,but I dont utilize half of the programs possiblities. So, I thought I would ask. thanks Quote
uddfl Posted February 23, 2009 Posted February 23, 2009 In 2d? No. It's not possible by means of standard AutoCAD commands, but wouldn't it be nice to have a program to do it for you. I wonder if someone has done it... Edit: One 'cheat' could be to use the EXTRUDE command, then explode and flatten the 3dsolid. Quote
Noahma Posted February 23, 2009 Posted February 23, 2009 Autocad architecture can do this, but it is not native for Autocad plain. It creates your roof in 3d using two tools, roof and roof slabs. Quote
BIGAL Posted February 24, 2009 Posted February 24, 2009 You can do it using "3dface" by joining 3d points together they must be a plane answer, say end would be 3 points 2 eave then ridge, side eave eave ridge ridge. Using "hide" your roof will appear solid. Way simpler than using 3d solids. You can certainly draw a house in full 3d without using solids check out the elevation & thickness commands draw 4 lines = wall with thicknes set to height of wall. Quote
ReMark Posted February 24, 2009 Posted February 24, 2009 Here's one way to do it with an add-on package: http://www.roofbuildertools.com/ Quote
ReMark Posted February 24, 2009 Posted February 24, 2009 A tutorial about drawing a simple roof in 3D in AutoCAD. http://www.dailyautocad.com/autocad/drawing-a-13-sloped-roof-in-3d/ Quote
ReMark Posted February 24, 2009 Posted February 24, 2009 A tutorial about drawing a more complex roof in 3D in AutoCAD. http://www.dailyautocad.com/3d/3d-roof-drawing-exercise/ Quote
ReMark Posted February 24, 2009 Posted February 24, 2009 AutoCAD 3D roof framing add-on: http://www.cadopolis.com/autocad_addons/AFV_Software_3D-FRAMER.shtml OK Kaner65 now it's your turn. Draw up your roof and post it here. What are you waiting for? It isn't going to draw itself. Quote
Kaner65 Posted February 24, 2009 Author Posted February 24, 2009 thanks for all of the suggestions. The roof building add-on programs are great. I had never heard of them before. Quote
ReMark Posted February 24, 2009 Posted February 24, 2009 You're entirely welcomed Kaner65. Let us know how you make out. Quote
