Hi, I have field in the table cell (gets value from one block's attribute) and I want to move or copy this to another cell or table, but CTRL+C and CTRL+V do not function. Inserted content (field) is than corrupted - object not found ####.... How to do this?
Edited by VAC
I can't find a simple way to do what you're asking. However, I did find a way to copy fields.
When you edit a field in the Field window, you'll see an expression in the bottom pane that defines the field. It begins and ends with percent (%) characters. Select that expression and copy it to the clipboard. You can then paste that expression into a text object. I tried it, and it works!
Thank you, I know this way but it is tedious and slow and I need to do many shifts. I don't understand why it doesn't work in the normal expected way (copy&paste).....
Edited by VAC
I did this script (CopyFieldBetweenCells) - works fine
(defun c:cfbc () ; VAC
  (setq obj (vlax-ename->vla-object (car (entsel "Pick table object"))))
  (while t
    (setq ans (vla-fieldcode (vlax-ename->vla-object (car (nentsel "Select Cell to Copy Field/Text: ")))))
    (setq ins (getpoint "\nSelect Cell to Insert Field/Text: "))
    (setq ans1 (LM:Hittest ins (setq Tables (Getacadtableobjects))))
    (vla-settext obj (nth 1 ans1) (nth 2 ans1) ans)
(Defun LM:Hittest ( Pt Lst ) ; Lee Mac
      (If (And (Vl-consp Pt) (Vl-every 'Numberp Pt))
        (Vl-some
          (Function
            (Lambda ( O / R C )
              (If (Eq :Vlax-true (Vla-hittest O (Vlax-3d-point (Trans Pt 1 0)) (Vlax-3d-point (Trans (Getvar 'Viewdir) 1 0)) 'R 'C)) (List O R C) )
          Lst
(defun LM:getattributevalues ( blk / enx ) ; Lee Mac
    (if (and (setq blk (entnext blk)) (= "ATTRIB" (cdr (assoc 0 (setq enx (entget blk))))))
        (cons
            (cons
                (cdr (assoc 2 enx))
                (cdr (assoc 1 (reverse enx)))
            (LM:getattributevalues blk)
Edited by VAC
