socacidan Posted September 26, 2023 Posted September 26, 2023 Hello, Is possible to have a lisp that easily replaces the object or set of objects referenced by a selected Field? As example, I found this old lips , but i would like not only to match text to text, but also to be able to match text to a field, a field content to another field. More simple to ask , to include next to "TEXT" "MTEXT" "ATTRIB" also "FIELD", so that would be possible to repace fast the reference of a field. And also another question, is possible to have a lips that matches the measurement from a dimension to a field... this i thik needs to be different lisp.... (defun c:mt (/ cEnt mEnt) (if (and (setq cEnt (car (nentsel "\nSelect Source Text: "))) (member (cdr (assoc 0 (entget cEnt))) '("TEXT" "MTEXT" "ATTRIB"))) (progn (redraw cEnt 3) (while (and (setq mEnt (car (nentsel "\nSelect Destination Text: "))) (member (cdr (assoc 0 (entget mEnt))) '("TEXT" "MTEXT" "ATTRIB"))) (entmod (subst (assoc 1 (entget cEnt)) (assoc 1 (entget mEnt)) (entget mEnt)))) (redraw cEnt 4)) (princ "\n<!> Incorrect Selection <!>")) (princ)) (defun c:mt2 (/ cEnt mEnt sLst) (if (and (setq cEnt (car (nentsel "\nSelect Source Text: "))) (member (cdr (assoc 0 (entget cEnt))) '("TEXT" "MTEXT" "ATTRIB"))) (progn (redraw cEnt 3) (if (setq ss (ssget "_X" '((-4 . "<NOT") (0 . "TEXT,MTEXT,INSERT") (-4 . "NOT>")))) (mapcar '(lambda (x) (redraw x 2)) (setq sLst (mapcar 'cadr (ssnamex ss))))) (while (and (setq mEnt (car (nentsel "\nSelect Destination Text: "))) (member (cdr (assoc 0 (entget mEnt))) '("TEXT" "MTEXT" "ATTRIB"))) (entmod (subst (assoc 1 (entget cEnt)) (assoc 1 (entget mEnt)) (entget mEnt))))) (princ "\n<!> Incorrect Selection <!>")) (command "_regenall") (princ)) (defun c:mt3 (/ cEnt ss) (vl-load-com) (if (and (setq cEnt (car (nentsel "\nSelect Source Text: "))) (member (cdr (assoc 0 (entget cEnt))) '("TEXT" "MTEXT" "ATTRIB"))) (progn (redraw cEnt 3) (if (setq ss (ssget '((0 . "TEXT,MTEXT")))) (foreach x (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))) (entmod (subst (assoc 1 (entget cEnt)) (assoc 1 (entget x)) (entget x)))))) (princ "\n<!> Incorrect Selection <!>")) (command "_regenall") (princ)) Quote
