When I change the color of a dimension in AutoCAD it changes other properties of the dimension as well, such as precision and arrow head size.  How do I change the color only?
How are you changing the color?
It sounds like you're using Match Properties and trying to match the color of one dimension to another, which will change all the properties of the dimension.
I use dedicated layers for my dimensions, so the dimension color is determined by which layer it's placed on.
I change the color from the properties dialog box. Don't matter how I select the dimensions, other properties change along with the color.
Try posting a drawing with a before and after and a few images or a video of what exactly you are doing.
