Hello.
When we use
(command "_image" "_attach" "C:\myimage.jpg" "" "0,0" 123 0)
It inserts image but saved path is relative
How to insert an image and save full path?
Thank you.
Edited by vanowm
Not sure if this will work in your particular situation, but INSERTOBJ (the OLE version of attach) lets you link an image as an OLE object. This page can get you started.
Keeping with the command method, would (command "_image" "path" "MyImage" -NewPath-) be any good - not sure if it will work. The site I was reading to use the old DOS formats to .\ would be to go up one level in the file system
