Hi I am trying to convert this georefimage lisp
I am using grads and my template units settings is :
(mapcar 'setvar (list 'aunits 'auprec 'angdir 'angbase 'lunits 'luprec 'insunits ) (list 2 4 1 (/ pi 2) 2 3 6))
This code work with deg and the results is wrong
(vl-load-com)
(if (null degrad)
  (defun degrad (ang)
    (* pi (/ ang 180.0))
(if (null raddeg)
  (defun raddeg (ang)
    (* 180.0 (/ ang pi))
(defun c:georefimg (/ img file res pt xres yres xrot yrot left top minpt maxpt im) ;define the function name and variables
  (princ "\nSelect Image or return to select image file to insert")
  (if (or (setq im (ssget ":s" '((0 . "IMAGE")))) (findfile (setq im (getfiled "Select Image File" (getvar "dwgprefix") "png;tif;jpg;ecw" 16))))  ;select the image to scale
      (if (= (type im) 'str)
	  (setq img
	       (vla-addraster
		 (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object))))
		 im
		 (vlax-make-variant (vlax-safearray-fill (vlax-make-safearray vlax-vbdouble (cons 0 2)) '(0.0 0.0 0.0)))
		 1.0
		 0.0
	  (if (snvalid (vl-filename-base im))
	    (vla-put-name img (vl-filename-base im))
	  (setq im (vlax-vla-object->ename img))
	(setq imG (vlax-ename->vla-object (ssname im 0)))
      (if (findfile (vl-string-subst ".ers" (vl-filename-extension (vla-get-imagefile img)) (vla-get-imagefile img)))
	(setq file (vl-string-subst ".ers" (vl-filename-extension (vla-get-imagefile img)) (vla-get-imagefile img)))
	(if (findfile (vl-string-subst ".tfw" (vl-filename-extension (vla-get-imagefile img)) (vla-get-imagefile img)))
	  (setq file (vl-string-subst ".tfw" (vl-filename-extension (vla-get-imagefile img)) (vla-get-imagefile img)))
	  (if (findfile (vl-string-subst ".jpw" (vl-filename-extension (vla-get-imagefile img)) (vla-get-imagefile img)))
	    (setq file (vl-string-subst ".jpw" (vl-filename-extension (vla-get-imagefile img)) (vla-get-imagefile img)))
	    (if (findfile (vl-string-subst ".pgw" (vl-filename-extension (vla-get-imagefile img)) (vla-get-imagefile img)))
	      (setq file (vl-string-subst ".pgw" (vl-filename-extension (vla-get-imagefile img)) (vla-get-imagefile img)))
      (if (or file (setq file (getfiled "Select World File" (vl-string-subst "" (vl-filename-extension (vla-get-imagefile img)) (vla-get-imagefile img)) "tfw;jgw;pgw;ers" 0)))
	(if (= (vl-filename-extension file) ".ers")
	    (setq file (open file "r"))
	    (repeat 19 (read-line file))
	    (setq left (atof (last (split (read-line file)  " ")))
		  top (atof (last (split (read-line file)  " ")))
	    (close file)
	    (vla-put-origin img (vlax-make-variant (vlax-safearray-fill (vlax-make-safearray 5 (cons 0 2)) (list left (- top (vla-get-height img)) 0.0))))
	    (vla-put-imagewidth img (vla-get-width img))
	    (vla-put-imageheight img (vla-get-height img))
	    (vla-getboundingbox img 'minpt 'maxpt)
	    (vla-zoomwindow (vlax-get-acad-object) minpt maxpt)
		  xres (atof (read-line file))
		  xrot (atof (read-line file))
		  yrot (atof (read-line file))
		  yres (atof (read-line file))
		  ins (list (atof (read-line file)) (atof (read-line file)) 0.0)
		  ins (polar ins (* (/ (+ xrot 90.0) 180.0) pi) (* (vla-get-height img) yres))
	    (close file)
	    (vla-put-rotation img (degrad xrot))
	    (vla-put-origin img (vlax-make-variant (vlax-safearray-fill (vlax-make-safearray 5 (cons 0 2)) ins)))
	    (vla-put-imageheight img (* (vla-get-height img) (abs yres)))
	    (vla-put-imagewidth img (* (vla-get-width img) (abs xres)))
  (princ) ;exit quietly
can any one help
Thanks
