HBBAS Posted November 10, 2023 Posted November 10, 2023 I need Lisp AutoCAD to merge a group of adjacent dimensions into one dimension that represents the overall dimension in one step. Quote
Steven P Posted November 11, 2023 Posted November 11, 2023 Assume a LISP called MergeDims to merge dims: "Dimlinear" click click, select 3 dimes, "Delete" - job done "MergeDims" click click click - job done Not sure if you are making much of a time saving or accuracy improvement from the sketch above with a LISP Quote
BIGAL Posted November 11, 2023 Posted November 11, 2023 Just use Dimaligned and pick start and end points. Note this is not actual true length. Could do a 5.4930 (5.503) which shows both. Quote
