mhy3sx Posted November 11, 2023 Posted November 11, 2023 Hi, I am using a lisp code to trim walls for door and window frames. In autocad everything works fine ,but in Zwcad "m2p" is not supported. Is any other way to trim the wall? ;; Break frame opening (command "_trim" "" "m2p" point1 point2 "m2p" point4 point3 "") Thanks Quote
marko_ribar Posted November 11, 2023 Posted November 11, 2023 ;; Break frame opening (command "_trim" "" "(mapcar '(lambda ( a b ) (/ (+ a b) 2.0)) point1 point2) (mapcar '(lambda ( a b ) (/ (+ a b) 2.0)) point3 point4) "") Quote
BIGAL Posted November 11, 2023 Posted November 11, 2023 A hint breaking 2 or 4 wall lines, you know wall thickness so always pick outside, then you know which way is in, so pick pt1 then pt2, can work out the break points. Quote
mhy3sx Posted November 11, 2023 Author Posted November 11, 2023 Hi marko_ribar. If I replace this (command "_trim" "" "m2p" point1 point2 "m2p" point4 point3 "") with this (command "_trim" "" "(mapcar '(lambda ( a b ) (/ (+ a b) 2.0)) point1 point2) (mapcar '(lambda ( a b ) (/ (+ a b) 2.0)) point3 point4) "") I have this error Error: malformed list on input Thanks Quote
BIGAL Posted November 12, 2023 Posted November 12, 2023 Look carefully you have an extra " just remove. (command "_trim" "" "( Quote
