Add user selection (lisp to change pattern of solid hatchs )
Hello!
I've been using a lisp from Lee Mac that changes all solid hatch to other predefined pattern (a big thanks to him although I'm a silent user of his work, original post here).
The lisp changes all hatch, including those in locked layers and both on model and paperspace.
I've made a few minor changes (ask for scale) but I would link to ask for a selection set and don't have the knowledge for it. I guess it's probably simple, and if so can you guys help on this?
(defun c:HHS ( / doc escala)
   (setq escala (getreal "\nEnter scale for ANSI31 hatch: "))
   (vlax-for blk (vla-get-blocks (setq doc (vla-get-activedocument (vlax-get-acad-object))))
       (if (= :vlax-false (vla-get-isxref blk))
           (vlax-for obj blk
               (if
                   (and
                       (= "AcDbHatch" (vla-get-objectname obj))
                       (= "SOLID" (strcase (vla-get-patternname obj)))
                       (vlax-write-enabled-p obj)
                       (vla-setpattern obj achatchpatterntypepredefined "ANSI31")
                       (vla-put-patternscale obj escala)
   (vla-regen doc acallviewports)
(vl-load-com) (princ)
Cheers,
Pedro T.
If you mean select a hatch and change its pattern across a selection then something like this.
(defun c:wow ( / ss obj x)
(prompt "\nSelect hatches ")
(setq ss (ssget '((0 . "HATCH")( 2 . "SOLID"))))
(if (= ss nil)
(alert "no hatches selected\n\nWill exit")
(setq obj (vlax-ename->vla-object (ssname ss (setq x (- x 1)))))
(c:wow)
Thanks so much Bigal that works great (I had to delete the last line, tho).
Would it be possible to change hatch within blocks also?
