Thank you very much in advance. I have the following code
  (defun premier ( /)
      (setq cnt 0)
      (while (< cnt (length list))
    (if (= 1 ACPV)
      (command "._SemiAutoGenerate" block "" ""  aling "" "" (nth cnt list) "" "" "" )
    (setq cnt (+ cnt 1))
    );end while
      );end defun
that calls a command that does not belong to autocad, but to an external application. My problem is that I have created a loop with while that repeats the command n times, I want that loop to be inside the command or use some type of subroutine. I think it's impossible. thank you so much
Edited by lozanoma
You may want Vl-cmf or vl-sendcommand method rather than using Command. Does it work if you say supply all values block,  aling & item in list. Make the 1 line and copy to command line.
(command "._SemiAutoGenerate" "MYBLOCK" "" ""  20 "" "" "LISTitem" "" "" "" )
First thank you for your response. The problem is that the list that is saved in "list" is a list of lists, it is not a single list, the problem is that I want to execute the list of list without the command being activated n times
Could you provide me with an example with vl-sendcommand?
Like this
(vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) "Vlide ")
(vla-sendcommand acdoc "_.script C:\\Alan\\blkins.scr") ; run script file as insert will read entire line
