itacad Posted December 7, 2023 Posted December 7, 2023 Good morning, I've recently been using Autocad 2024 and I can't resolve a problem with multiline texts. In the previous version, with a double click on a multiline text I was able to open its editor, find the text all selected and then decide whether to delete it all or where to position the cursor to be able to modify it. The new operation I'm experiencing is the following, with a double click on a multiline text the cursor becomes square and this message appears on the command line: EDITAIM Selezionare un oggetto TESTOM: At that point I select the text I want to modify and only then does the editor open with the cursor already inserted inside at a midpoint. Are there any settings available to edit multiline texts as I was used to doing? What has been described also applies to single line texts which however I use little. Greetings Quote
SLW210 Posted December 8, 2023 Posted December 8, 2023 11 hours ago, BIGAL said: Why not use Mtext ? Mtext = multiline text. Quote
itacad Posted December 18, 2023 Author Posted December 18, 2023 I solved! I found this discussion https://www.autodesk.it/support/technical/article/caas/sfdcarticles/sfdcarticles/ITA/Doubleclick-on-Block-do-not-show-the-selected-blocknacme-and-doucbleclick-on-Mtext-do-not-open-editor-in-AutoCAD.html Quote
