Samr1979 Posted December 21, 2023 Posted December 21, 2023 We are trying to make a block with text attributes that will show sizes but I need the fractions to show up as stacked and diagonal. Is there a way to do this? Quote
BIGAL Posted December 21, 2023 Posted December 21, 2023 (edited) Maybe this https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-set-the-default-format-for-stacked-fractions.html Edited December 21, 2023 by BIGAL Quote
OMEGA-ThundeR Posted January 23, 2024 Posted January 23, 2024 On 12/21/2023 at 4:09 PM, Samr1979 said: We are trying to make a block with text attributes that will show sizes but I need the fractions to show up as stacked and diagonal. Is there a way to do this? Could this be a random fraction? Or will it have a set number of values? If it's a set amount of values you could use a visability with a set of values. But as far as i know there isn't any kind of 'conditional' content. Would be nice to have some 'if / then' condition with some formula attached. If the fraction is in a fixed location you could try and use some formula on 2 extra attribute (X/Y) or fields texts linked to some dimension or other calculation. Having a formula that auto updates on refresh is better than a visibility that you can forget though. Quote
