katto01 Posted January 3, 2024 Posted January 3, 2024 Hello, Is it possible to set/modify/delete geometrical constraints in AUtoCAD with VBA? Same question fro ZWCAD. Thank you Quote
BIGAL Posted January 4, 2024 Posted January 4, 2024 (edited) Explain more what you mean by set/modify, you can set a value of a constraint, say enter length. What is the delete constraint end result, how will it affect an object. Edited January 4, 2024 by BIGAL Quote
katto01 Posted January 4, 2024 Author Posted January 4, 2024 simply using VBA to set a dimension constraint and /or delete a dimension constraint Quote
BIGAL Posted January 4, 2024 Posted January 4, 2024 You need to post a sample a before after is best. Quote
Danielm103 Posted February 3, 2024 Posted February 3, 2024 You can modify dimensions, there’s nothing in the API regarding constraints Quote
