Lisp for match rotation angle between objects (works on multileaders) - combined from 2 found lisps on the internet, with the help of A.I.
;;; Rotate by existing object/angle - Debugging (including Multileaders)
(vl-load-com)
(defun C:RB (/ sourceObj rot targetObj)
  (defun convert-to-double (angle)
    (vl-catch-all-apply 'rtos (list angle 2 2))
  (setq sourceObj (car (entsel "\nSelect the source object for rotation < specify manually >: ")))
  (if (setq sourceObj (vlax-ename->vla-object sourceObj))
        (setq rot (vla-get-rotation sourceObj))
        (setq targetObj (car (entsel "\nSelect target object to be rotated: ")))
        (if (setq targetObj (vlax-ename->vla-object targetObj))
            (if (not (vl-catch-all-error-p
                       (cond ((and (eq (vla-get-objectname targetObj) "AcDbMLeader") (eq (vla-get-contenttype targetObj) 2))
                                (vla-put-textrotation targetObj (convert-to-double rot))
                                (vla-put-rotation targetObj (convert-to-double rot))
                              )) ; Rotate multileader text and block to the source object's rotation
                             (t
                              (vla-put-rotation targetObj (convert-to-double rot)) ; Rotate other objects
                (prompt "\nRotation applied successfully.")
                (prompt "\nCannot apply rotation angle!")
      (prompt "\nError: Source object not selected.")
Rotate Object by another's angle-RB.lsp
Edited by SLW210
Added Code Tags!!
Just a quick one a circle, line, arc etc do not have a rotation property. So if for multi leaders then can change then entsel to a ssget and only pick mleaders.
