Can someone help me understand HOW to fix the CROSS-SECTION CURVES MUST ALL BE ALL OPEN OR ALL CLOSED.
https://easyupload.io/1n9zss
I've tried X-slicing each of the 2 objects into 4 pieces, deleting the middle 2, and then creating a LOFT object (which I thought was supposed to be SOLID) and then trying to do a final LOFT between those 2 solid object, but every time I try one of the surfaces gets deselected with the error above.
Could someone help me explain how to correct this?
Thanks in advance
Edited by MikeK
Wrong error message
