Subtract solid without losing original?
I spend a lot of time copy/pasting solid objects on top of themselves so that I can subtract them from another solid.
Is there a way to subtract a solid from another without losing the original? Or are there other more efficient ways of doing this operation?
Thanks
The old school way: save a copy on another layer that is normally kept frozen. Doesn't figure into any regens.
Enter DELOBJ in the command line. When prompted for the new value, enter 0 -this should take you where you wish.
Also there is a command called INTERFERE -it can be used to create the intersection of two or more solids, also without deleting them.
  • 1 year later...
I've set delobj to 0 and subtract still erases the original with regions.
DELOBJ needs to be either 1 or 2 not 0.
Autodesk Inventor. Modern 3D programs like Inventor allows you to choose to Union, Cut or Intersect and elect to keep the original toolbody.
Cad-e: AutoCAD 2005 to Inventor 2011. Man, that is going to be some shock. And I'm not just talking sticker shock. I don't suppose you're a student are you? What kind of work do you do?
