EnricoTV Posted February 2, 2024 Posted February 2, 2024 (edited) Hello everyone, Is it possible to create a lisp that selects specific hatches and blocks and resets all the hatches from “Annotative property” to “Non-Annotative”, including nested blocks (without explode them)? Thanks a lot Edited February 2, 2024 by EnricoTV Quote
pkenewell Posted February 2, 2024 Posted February 2, 2024 (edited) @EnricoTV You might want to explain a little more. Are you wanting to batch "100's of drawings" like so many that have asked? Because if no, you don't need a program; you just select all the hatches with the Quick Filter command, then change them all at the same time in the properties pane: EDIT: OH I see you also want in blocks and nested blocks as well as all the top level Hatches. Yep that'll take a bit more. Sorry - don't have time to write something for you like that. but someone may have something done already out there Edited February 2, 2024 by pkenewell Quote
EnricoTV Posted February 5, 2024 Author Posted February 5, 2024 On 2/2/2024 at 9:44 PM, pkenewell said: @EnricoTV You might want to explain a little more. Are you wanting to batch "100's of drawings" like so many that have asked? Because if no, you don't need a program; you just select all the hatches with the Quick Filter command, then change them all at the same time in the properties pane: EDIT: OH I see you also want in blocks and nested blocks as well as all the top level Hatches. Yep that'll take a bit more. Sorry - don't have time to write something for you like that. but someone may have something done already out there Thanks anyway for your reply Quote
