nrschmid Posted September 20, 2007 Posted September 20, 2007 I have a bunch of intersecting polylines. I would like to extend one polyline in one direction, and then have that polyline divide other polylines into separate parts. Can this be done? Is there an lsp file or plugin that I need? Thanks- Quote
lpseifert Posted September 21, 2007 Posted September 21, 2007 Credit where credit is due... to CAB Quote
Guest Alan Cullen Posted September 21, 2007 Posted September 21, 2007 CAB is doing well today. That's two that have been accredited to him. Quote
nrschmid Posted September 21, 2007 Author Posted September 21, 2007 thanks for the file. New to using most lsp's. I saved the filed as breakobjects.lsp and loaded it into CAD. What commands can I use? Does part of the text not need to be copied over? Thanks- Quote
GhostRider Posted September 21, 2007 Posted September 21, 2007 Nrschmid There are several commands to start this lisp, usually listed at the top if you open the file in a notepad or another text editor these are the commands listed and what they do. This one is cool I am trying to learn too... ;;; Function c:BreakAll - Break all objects selected ;;; Function c:BreakwObjects - Break many objects with a single object ;;; Function c:BreakObject - Break a single object with many objects ;;; Function c:BreakWith - Break selected objects with other selected objects ;;; Function c:BreakTouching - Break objects touching the single Break object ;;; Function c:BreakSelected - Break selected objects with any objects that touch it Usually after you load a lisp in the command window it shows the command to start the routine like this : C:BREAKSELECTED Quote
lpseifert Posted September 21, 2007 Posted September 21, 2007 The .lsp should be complete; there is nothing that "not need to be copied over". Quote
Guest Alan Cullen Posted September 21, 2007 Posted September 21, 2007 nrschmid, Further to what lpseifert said, it is bad practice to alter someone's Lisp without their permission. Quote
nrschmid Posted September 21, 2007 Author Posted September 21, 2007 Well thanks for the update. I am also having to reload the lsp files each time I restart AutoCAD through appload. Anyway around this problem (I am thinking click on startup suite?) Quote
Guest Alan Cullen Posted September 22, 2007 Posted September 22, 2007 Find or create a file called acaddoc.lsp, the add this line to it (load "lispname.lsp"), where lispname is the name of the lisp file you want to load. Then save the acaddoc.lsp to the support folder of your acad installation. Quote
devitg Posted September 24, 2007 Posted September 24, 2007 nrschmid, Further to what lpseifert said, it is bad practice to alter someone's Lisp without their permission. This is on the lisp head You are hereby granted permission to use, copy and modify this ; ;;; software without charge, provided you do so exclusively for ; ;;; your own use or for use by others in your organization in the ; ;;; performance of their normal duties, and provided further that ; ;;; the above copyright notice appears in all copies and both that ; ;;; copyright notice and the limited warranty and restricted rights ; ;;; notice below appear in all supporting documentation. ; ;;;===================================================================== So, he allow to modify it Quote
yostcaleb Posted May 1, 2018 Posted May 1, 2018 thanks for the file. New to using most lsp's. I saved the filed as breakobjects.lsp and loaded it into CAD. What commands can I use? Does part of the text not need to be copied over? Thanks- Is this lisp still available? Quote
