RLory Posted February 26, 2009 Posted February 26, 2009 Multileaders not displayed in previous releases of AutoCAD® Published date: 2008-Aug-21 Applies to: AutoCAD® 2009 AutoCAD® 2008 AutoCAD LT® 2009 AutoCAD LT® 2008 Issue You created multileaders in AutoCAD®, but when you open the drawing in AutoCAD 2007 or a previous release, the multileaders were not displayed. Solution To display multileaders in previous releases of AutoCAD® In the current release of AutoCAD, before saving the drawing, set the value of the PROXYGRAPHICS variable to 1. In the previous release of AutoCAD, before opening the drawing, set the value of the PROXYSHOW variable to 1. Hope this helps. Quote
