Guest Cyclopean Posted November 12, 2002 Posted November 12, 2002 As I said earlier, I'm new to the 3d/rendering side of CAD. I've completed my drawing, and I've applied materials from the materials library, now I've rendered it. How do I print this finished product? When I print, I see only the wireframe of the dwg. Thanks for any help. Quote
Guest superjari Posted November 12, 2002 Posted November 12, 2002 In the render window set the destination to file rather than to viewport or render window... Quote
f700es Posted November 12, 2002 Posted November 12, 2002 As I said earlier, I'm new to the 3d/rendering side of CAD. I've completed my drawing, and I've applied materials from the materials library, now I've rendered it. How do I print this finished product? When I print, I see only the wireframe of the dwg. Thanks for any help. Hello Cy, you cannot print a rendered image in AutoCAD. You have to render to a file. In your render dialog box choose file as you destination. Like this.... http://members.tripod.com/F700ES/render-file.gif F7 Quote
CADTutor Posted November 12, 2002 Posted November 12, 2002 Also, see here http://www.cadtutor.net/acad/acad2ki/atop/atop.html#Render for a full description of this process. Obviously, once you've rendered your file, you'll need to print it using some bitmap editor like Photoshop or Paint Shop Pro. Quote
gcp310 Posted December 3, 2002 Posted December 3, 2002 or insert your image into word. i know,i know. word is not the best page layout program. but everyone has it. G Quote
Mr T Posted December 3, 2002 Posted December 3, 2002 Click the LAYOUT tab Pull down INSERT menu, RASTER IMAGE Click and drag a box the size you want. Print (by typing PLOT) Nick Quote
jalba Posted June 25, 2010 Posted June 25, 2010 Hi I am having a lot of trouble trying to set the render destination to "file". I am just not seeing it AT ALL!!! all i got is viewport and window. note: i followed this pathway: View - Render - Advanced Render Settings *i use autocad 2010. What am i doing wrong? Quote
JD Mather Posted June 25, 2010 Posted June 25, 2010 This is from 2011, but I don't remember being all that different in earlier releases. File>Save As... Quote
jalba Posted June 25, 2010 Posted June 25, 2010 so let me ask you this....where is superjari getting able to set the render to save as a file? "In the render window set the destination to file rather than to viewport or render window..." Quote
