Guest SWFLACAT Posted September 15, 2004 Posted September 15, 2004 can anyone help me with a program, or methodology, to convert Architrion files to AutoCad? Thanks in advance! Quote
Mr T Posted September 15, 2004 Posted September 15, 2004 can anyone help me with a program, or methodology, to convert Architrion files to AutoCad? Thanks in advance! Save as or Export as DWG or DXF or WMF ??????????? Nick Quote
KFoster Posted December 27, 2011 Posted December 27, 2011 If you are able to open the Architrion drawing in Architrion, be sure to smash all accessories and text to line segments and arcs since the fonts WILL NOT transfer in proper size. It is your decision whether to do the same with the dimensions. SOMETIMES this will allow "live" dimensions to be transferred w/ .dxf to the ACAD .dwg format, sometimes not. If not, smash the dimensions to text, then smash the text to line segments. Probably a good idea to have all dimensions on a separate layer... Quote
SLW210 Posted December 28, 2011 Posted December 28, 2011 I hope this has been resolved in the past 11 years. Quote
Jack_O'neill Posted December 28, 2011 Posted December 28, 2011 I did a google search on this and couldn't find anything newer than about 2006. My suggestion, print them from architrion on paper and archive them. If you do, you can probably redraw any you need faster and more accurately than it would convert or even dole out a little outsource work to those of us who do that sort of thing for a living. Quote
