Adding to existing LISP
PaulyPHI
Hi there, I am a bit thick when it comes to lisp files so be easy with me. I understand some commands and reasoning but then i just get lost.
I have acquired the attached LISP routine and have been using it to draw 3d sections across contours.
All i want to do is have it set the drawn 3dpolyline to a specified layer and then return to layer 0 when action is completed.
I tried finding a LISP that already selects a layer and splice that in but it fails drastically...
Any help would be appreciated.
Paul
Slice3d.lsp
@PaulyPHI
Ok - Try This:
1) Right after the line with (setq usercol..., insert as shown:
   (setq usercol (acad_colordlg 10));<---Did you add this line? If so you can delete it and add the desired color to the part below.
); <----DELETE THIS Extra Right Parenthesis! program won't work with it.
   ;; Insert these lines and change the indicated values to your preference.
   ;; Make Layer if not already in drawing and set Color and Linetype.
                                   ;Layer Name|
   (if (not (tblsearch "LAYER" (setq lyr "MyLayer")))
                                  ;Color|       Linetype|
      (command "._-layer" "_m" lyr "_c" 1 lyr "_l" "Continuous" lyr "")
   (setvar "clayer" "0")
Set the Layer name, Color, and Linetype to your choosing.
Then Replace the following line:
(entmakex '((0 . "POLYLINE") (10 0.0 0.0 0.0) (70 . 8)))
TO:
(entmakex (list (cons 0 "POLYLINE") (list 10 0.0 0.0 0.0) (cons 70 8)(cons 8 lyr)))
I can't test so let me know if this is what you wanted and it works.
Edited by pkenewell
@pkenewell many thanks for that, works perfect...
I sort of understand what each line does but each command seems cryptic rather than plain text to me.
Its all the spaces and " bits.... i wish my brain could decipher exactly what you wrote as i read it but it can't.
As i said many thanks.
Paul
How is this? Lots of comments to Help:
   (if ;; begin If Statement.
      (not ;; Logical NOT: Returns T if test fails.
         (tblsearch ;; Function to find a value in a symbol table.
            "LAYER" ;; Table to search.
            (setq lyr "MyLayer") ;; Specify the Layer Name to Seach for and set it to a variable.
      ;; If no layer was found, start the LAYER command to make it.
      ;; Notes on pre-command modifiers:
      ;; "." forces the original command name, in case it has been redefined.
      ;; "_" allow command to work on non-english versions of AutoCAD.
      ;; "-" is needed on some commands to specify the command-line (no dialog) version.
      (command
         "._-layer" ;; command name.
         "_m" ;; "Make" Option.
         lyr  ;; Layer Name variable created above.
         "_c" ;; "Color" Option.
         1 ;; Integer representing the ACI color number (RED).
         lyr ;; Apply it to new Layer Name.
         "_l" ;; "Linetype" option.
         "Continuous" ;; Name of Linetype.
         ""  ;; Empty string represents [Enter].
      ) ;; End Command
   ) ;; End If
   ;; Set the current layer to "0"
@pkenewell i will have to take more time out from drawing poxy retaining walls and have a play at simple LISP files for my self.
Many thanks
Paul
