Converting MS to PS and vice versa
Can you convert objects (text) from model space to paper space?
you can if you have express tools loaded
from PS click into model space and use chspace command, select what you want to move.
vice versa too
Based on a previous post, I understand that LT does not have Express Tools. Is that correct?
Use Copybase, switch spaces. Paste, before you select an insert point type S for scale, enter a scale factor, then an insert point. Switch spaces, Erase > Previous
Don't you wish you had full acad...
good call! I missed that completely
