Jadeous Posted February 27, 2009 Posted February 27, 2009 Ok, so I have numbered the parts in my drawing and pulled the little number bubble away and streached the leader out. My problem is that the Bossman doesn"t want leaders! So now I am stuck with Leaders! I heard of a command that solves this problem, but it has slipped my memory. Please help. Thank you. Quote
lpseifert Posted February 27, 2009 Posted February 27, 2009 If you're talking of Multileaders with a Detail Callout Block, in Properties you can set the Leader type to none. Quote
Jadeous Posted February 27, 2009 Author Posted February 27, 2009 I am using the CADDuct item numbers in ADT. When I move the number out it has a pink triangle attached to it. If I pull the triangle out it creates a leader. Quote
Strix Posted February 28, 2009 Posted February 28, 2009 let's put your question in the ADT forum then, where it should be spotted by somebody familiar with that function Quote
