drawing a ball bearing in AC 2006
BOOJAN
Some of the spheres are off center and the cages are intersecting each other. As far as the faceted faces I can't remember that much about AutoCAD to recall what settings to change before creating the solids.
facetres=10 does improve a bit, but...
  • Replies 30
  • BOOJAN
    11
  • Lee Mac
    6
  • fuccaro
    5
  • JD Mather
    3
Posted Images
i solved the problem.....btw tnx for offering to help me....
it doesnt look nice like fuccaro's ball bearing, but i like it :)
Actually now that I look a bit more the cages aren't parallel and there is an extra side (gray moved in attached).
so that gray cage is my misstake?? as i remember i didnt make 2 cages at one side...but nevermind now i know how to draw ball bearings thanks to all good people on this forum
That is some fantastic rendering JD Mather - you have talent.
Suggest entering for Image of the Week... :P
is that rendering made in ac, or in some other program??
I just found an other construction for the ball bearings:
The cages differ a lot, and also the material is unusual.
Credit for this project: Leonardo da Vinci
  • 1 month later...
