Guest Posted March 2, 2009 Posted March 2, 2009 I have recieved *.SHP file from somone, and I am unable to open the file. When I Google the file, it says that the file can be opened with Auto CAD. Would anyone know how to open it in Auto CAD? Thanks. Quote
CarlB Posted March 2, 2009 Posted March 2, 2009 This is likely a "shapefile" created gy a GIS application. AutoCAD Map can propbaly open/import it but I don't believe plain AutoCAD can. This is sometimes confused with an Autocad "shape file" for creation of shapes for complex linetypes and fonts. A .shp is an ASCII file which gets compiled into a .shx file for use. Quote
rayw Posted March 3, 2009 Posted March 3, 2009 I too have a .shp file than can't be found on a certain plan that I open. I just click "Cancel" at the error/warning window and the plan opens fine. My question: is there any way to detach this file from the drawing and get rid of the pesky startup window? Quote
CarlB Posted March 3, 2009 Posted March 3, 2009 Try the procedure RK details: http://rkmcswain.blogspot.com/2006/02/select-shape-file.html Quote
rayw Posted March 3, 2009 Posted March 3, 2009 Thanks CarlB I found the SHP file using the lisp routine from your referenced article but I can't delete it. Turns out it is a linetype. I did a Qselect for that linetype and nothing showed up. I tried to delete the linetype but deletion was not allowed. And it did not show up in purge. I could probably delete it using the hard-purge software also in your referenced article but this is only a minor inconvenience so it is not worth buying the program at this point. I'm going to fool around some. See if I can create a simple SHP linetype, give it the name of the "not found" one, then try to substitute at startup. Maybe then I can delete it once it is "found" in the drawing. Quote
Guest Posted March 3, 2009 Posted March 3, 2009 Thanks CarlB. I guess that I will need to tell somone they are SOL then. Quote
