Breaking Leader !
Hello everybody!
I have some troubles when use Leaders on my drawing. The Leaders are usually cut the dimension or other objects. Im used to solve them by using a leader and a polyline, but that is an unprofessional way. I don't know how to break the Leader without using polyline like I have done before.
If you have any solution to solve, please help me bacause that is really useful with me as well as who meet this trouble as me.
Thank you in advanced!
Thanh An,
Explode the leader then use the Break command to create the gap.
If you use an Mleader, you can use the Dimbreak command
DIMBREAK: "Breaks or restores dimension and extension lines where they cross other objects."
I don't see where this applies to the leader itself. Maybe I am misunderstanding the OP's question. I get the feeling he wants to break the leader and not the dimension or extension lines. I could be wrong.
Try Dimbreak with a Multileader
Command: _DIMBREAK
Select a dimension or [Multiple]:
Selected object is not a dimension or multileader.
The most wise and all powerful OZ has spoken. Thank you master.:)
Erase the line the "broken" multileader crosses and the multileader then "heals" itself. Neat.
MLEADERS, DIMBREAK, and DIMSPACE (When I forget to set DIMDLI for baseline dimensioning) make annotating any drawing a breeze.
Oh, I don't know what to say thanks to you for your help. But I only apply to Multileader. Now, these is a small trouble is how to convert Leader to Multileader. Only that, I can use Dimbreak Command to break the Multileader.
Thanks for you ideal.
Thanh An
