Hi
Is there a easy way to show numbers or letters with a circle (or any shape) around them other than physically drawing a circle around the text.
thanks
You're talking about "balloons"?
AH
How do i create balloons?
Try Mleader (Mleaderstyle) and select Block as the Mleader Type; there are a number of types you can select from, including Circle. If you don't want the leader, you can turn it off in Properties.
Taking lpseifert's advice re: MLeader. Hmmm...does Civil 3D work a bit differently than plain AutoCAD?
In AC 2009 it's MLeader > Options > Content type > Block. Then the user is prompted to Enter block name. There does not seem to be any "types" listed what-so-ever. Am I doing this wrong?
You also got TCIRCLE...... :)
lpseifert...my apologies. I was doing it by way of the command line. However, if one uses the MultiLeader Style Manager > Modify, clicks on the Content tab and under MultiLeader type selects Block then under Block Options are the following choices: Detail Callout, Slot, Circle, Box, Hexagon, Triangle and User Block.
Thanks for teaching me something new today. It won't be a wasted day after all.
Use attribute with desired shape and text. Then you can use copy and paste. Then replace the attribute text next time.
Tom
