TimZilla Posted March 5, 2009 Share Posted March 5, 2009 I make an arc. Put it right in the middle of a circle in 2d. Orbit into 3d mode. Draw a line standing straight up. then I use the regular old rotate command using a reference to stand the arc up next to the line, erase the line. Then I use extrude, select the object (circle) select the path option. click on the arc and BAM. A 90 degree Ell is there. Could be an easy way but it works for me Quote Link to comment Share on other sites More sharing options...
