smooty5000 Posted March 4, 2009 Posted March 4, 2009 I am trying to create a template for starting new projects with project navigater. I want to create two views for new floorplan and demo floorplan the layer names and states are always the same but the xref name can change. Is there a way set up a view so that it always has for instance layer "A-demo" off regardles of what the preceding xref drawing name is? secondly is there a way to change the location were navigator creates and saves new constructs and elements? Quote
Se7en Posted March 10, 2009 Posted March 10, 2009 You dont create Views in your template. The only thing(s) i created in my (Those things that could be considered ``standard'' enough to do so) are some Elements. yes; right click on the project in the Proj Browser. Quote
Noahma Posted March 10, 2009 Posted March 10, 2009 You dont create Views in your template. The only thing(s) i created in my (Those things that could be considered ``standard'' enough to do so) are some Elements. yes; right click on the project in the Proj Browser. We have all of our views setup in the template, complete with layers needed for doing our documentation (we use a non standard layering system) They have the correct constructs x-ref'd into the file and have the layer colors changed to what is needed IE lighter wall lines when in a framing view for documentation. Quote
Se7en Posted March 11, 2009 Posted March 11, 2009 We have all of our views setup in the template, complete with layers needed for doing our documentation (we use a non standard layering system) They have the correct constructs x-ref'd into the file and have the layer colors changed to what is needed IE lighter wall lines when in a framing view for documentation. *sigh* Were/are you just thinking of answering the initial question or are you just bragging? Consulting office or A/E firm? Do you saveas and navigate the directory structure or do you still ``right click''? Do you use Display config's for screening wall lines or layer overrides? Quote
